tool bar
/ tool bar #1
bdog
Elite Member
Texas
John Deere 6130M
I have noticed a lot of the farmers here have their equipment mounted on 3 point mounted tool bars instead of drag behind. They look like they are 4" square tubing. I was thinking of making one for my tractor that was only 8' wide or so but still using 4" so that I could use the "tools" that fit the bigger tractors. I see a lot of this stuff at farm auctions for fairly cheap and thought it would be neat if I rigged up my tractor to accept these. Has anyone ever done this? I don't think I have ever seen a tool bar on a small tractor but I don't see any reason why it would not work.
/ tool bar #2
It'll work as long as you don't overmatch the tractor. Tool bars give you a lot of versatillity. The idea of picking up tools at an auction is the way to go.
/ tool bar #3
Here's a soil ripper converted to 3 pt on my JD 4010. The 7 chisel plows are on a tool bar.
Ralph
/ tool bar #4
Here are 2 disc hillers mounted on the same tool bar.
These are 16" dics hillers I used to make raised rows in my garden. I've bought some 12" disc hillers and plan to mount them with 3 or 4 of the chisel plows to maintain the rows I've made in the fall-spring period.
The 18.5 hp JD 4010 pulled the big disc hillers mounted at opposed 45 degree angles with no problem at all. It also pulled the 7 chisel plows to their maximum depth with no problem, with turf tires.
Ralph
/ tool bar #5
</font><font color="blue" class="small">( I have noticed a lot of the farmers here have their equipment mounted on 3 point mounted tool bars instead of drag behind. They look like they are 4" square tubing. I was thinking of making one for my tractor that was only 8' wide or so but still using 4" so that I could use the "tools" that fit the bigger tractors. I see a lot of this stuff at farm auctions for fairly cheap and thought it would be neat if I rigged up my tractor to accept these. Has anyone ever done this? I don't think I have ever seen a tool bar on a small tractor but I don't see any reason why it would not work. )</font>
If I was at home now, I'd post a few pictures for you. I have taken several old (6 to 8 row) cultivators, mounted on 4" toolbars, and made planter frames, smaller cultivators, and a few other odds and ends. The cultivators are available at a CHEAP price. It seems that no one uses them much anymore.
There are three common sizes of toolbars, and each of them can come in two distinct variations. 2"X2", 4"X4", and 4"X7" will commonly be found. (4"X7" on BIG equipment only)
The 2"X2" and 4"X4" can be "square" or "diamond" (One "flat side" square with the ground, or rotated 45 degrees to the "diamond" position)
Older mounted cultivators usually had a toolbar mounted set of shanks BEHIND the tractor to eliminate tire tracks. They are usuall 2"X2" diamonds. There is a good source of the bar AND the three point hitch brackets too. Newer style rear mounted cultivators (4,6,8, and even 12 row) usually are mounted on a 4"X4" bar.
I've been finding GOOD 8-row units for $100 to $200 at sales and on internet classifieds. Typically, with an 8-row unit, you get a 21' section of 4"X4" square tubing, a complete set of hitch parts, and a BUNCH of cultivator shanks. (Scrap prices are way up too!!!)
Generally, 6-row and bigger equipment is CAT.II or CAT.III hitch, but the mounts are adjustable in width too. Just change out the lower link pins, and you're on your way!
If you're interested, PM me with your email addy, and I'll send you a few pictures of some "home-made" hitch parts, and a few "toolbar mounted" impliments I've built.
Bill
2023 BOBCAT T66 R-SERIES SKID STEER (A62129)
2023 BOBCAT T66...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
1994 SHOP MADE ENCLOSED TOOL TRAILER (A58216)
1994 SHOP MADE...
Butler MFG Water Tanker (A63118)
Butler MFG Water...
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
