Tool/ballast box
   / Tool/ballast box #1
gsmaneeley
Bronze Member
Pulaski, NY
Kubota BX2660
I am wondering if a jobox style tool box could have cat1 pins welded on and made to be a ballast box which could double as a tool box? Anyone see any problems that stand out?
   / Tool/ballast box #2
I see no issues I'm sure you could make it work.
   / Tool/ballast box #4
yeah I see problems with it as a ballast box. you would need to reinforce the whole thing. just welding pins to the side is going to make the sides buckle if you put a good amount of ballast in it. the pin area will be stressed a lot. Job box tool boxes were not meant to be suspended in the air with 500-1000 pounds by 2 pins welded to the side. The pins will probably just bend up wards taking the sides with it.
   / Tool/ballast box #5
I agree with big mike. I should have said it before but I thought it went without saying that you would have to reinforce it and do some fab to hook up the toplink.
   / Tool/ballast box #6
I would suggest a heavy angle iron frame and platform for the box to set on, that way if you have tools in it and do not want to load with ballast, one could set two 30 or 55 gallon drums on the platform for ballast, and if it is platform one could use it for a mini pickup or carry all,
3-Point Tractor Platform | Huckins Forge
Tractor 3 Point Hitch, Category 1, Carry All With Frame
some thing like a three point bale mover, ( the kind with the forks) with a bolt/pin on platform
Pegasus Industries Inc.
   / Tool/ballast box
I thank you all for the ideas. I was originally thinking if it was strong enough to hold all the tools it would be strong enough for ballast. I didn't think about the pins putting all the stress in one location. I am going to rethink how I could do this
2021 Kubota SVL75-2 Track Loader (A56438)
2021 Kubota...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2018 FREIGHTLINER...
2017 Toro Sand Pro 5040 Bunker Rake (A59228)
2017 Toro Sand Pro...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
2001 John Deere 6210 (A60462)
2001 John Deere...
