Tiller took the plunge on a tiller
   / took the plunge on a tiller #11
I look forward to the review as I have been debating over the same tiller. They sure look well built.
Your tiller got to do some traveling. I think King Kutter is located in Winfield AL which is around 200 or so miles from Rutledge.
well i contacted the tractor supply company in greenville 3 times about getting one from them and never got a reply i talked to a dealership in montgomery that wanted 2500.00 for just the tiller all in all you win some you lose some it might not have been the best deal but i guess i got wore down from looking at so many places and getting the run around either way i think itll be a great piece of equipment to use and mostly figure out and tinker with its just something about the way the air changes that says ok its time to put something in the ground lol now if i could just get a day off to go see it i wont even be there to unload it thats almost a sin
   / took the plunge on a tiller #13
We still have a lot of snow on the ground here, but it's melting fast. Temps in the 50's all of a sudden. I hope to get my KK 7' tiller ordered within a week, and that should bring on some more winter weather.
Your price is about $100 less than I am getting, but my shipping is much less since I'm in Ohio. The tillers are built in Ohio. The 7' KK looks like it has a little beefier 3ph pin set up, probably due to the weight. I think it's cat 1 or 2. I haven't seen any specs on it and even the KK site doesn't list it. I've only seen photos of them on ebay or dealer sites.
Good luck with it - I'm sure you'll enjoy it!
   / took the plunge on a tiller #14
I not sure about the shipping,but I have a 6ft KK and it will pulverise hard clay in one pass.I think it`s geared to spin faster than other tillers I`ve had.
   / took the plunge on a tiller #15
Looked at a bunch of tillers today, wound up buying a KK II 72" for $1750 out the door. Thats serviced (oil in gearbox, slip clutch adjusted, etc), and put in my pickup truck. Will pick it up Tuesday from an Ohio dealer. He also carries Tarter, Woods, and Taylor Made (KK II with a different top). He sure had a lot of tillers in stock.
Stopped at another dealer on the way there, and he was getting over $4000 for a 6' Bush Hog reverse-tine tiller and over $3200 for the "regular" one. Dang. Got out of there in a hurry.
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2009 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A58017)
2009 PETERBILT 387...
Hydraulic Breaker (A55973)
Hydraulic Breaker...
Semi with Box Bed (A55973)
Semi with Box Bed...
2017 Ford F-150 Pickup Truck (A55973)
2017 Ford F-150...
