Took the plunge, Finally!!!
   / Took the plunge, Finally!!! #1
Gobblin Tom
Western, PA
2011 JD 2520
I just went and ordered a new 2520 with FEL, bucket teeth, drive over MMM, 57" Frontier tiller, i-match, 3pt receiver, rim guard in rear tires, rear tire chains, also had them put hooks on bucket and one on top of my 3pt receiver. I hope I didn't miss anything? I have been looking/lurking here for a while and learning along the way!
   / Took the plunge, Finally!!! #2
Congrats Tom - when does it all arrive? Make sure you post us some pics :thumbsup:
I told them not till I get back from my Turkey hunting trip in Nebraska, so it will be 10-12 days he said. Tractor is already there.... I did get the 61" bucket also. Can anyone tell me if you get the independant mower lift or is that something you have to specail order?
   / Took the plunge, Finally!!! #4
The independent lift is extra and usually runs around $700
What is the advantage vs disadvantages of it?
what are the advantages vs disadvantages of the independent mower lift? anyone....???
   / Took the plunge, Finally!!! #7
"what are the advantages vs disadvantages of the independent mower lift? anyone....??? "
I guess the theoretical advantage is that you can raise/lower the mower without raising/lowering the three-point hitch. However, because the independent lift comes off the loader circuit, it will leak down, which means you have to keep adjusting the height of the mower (unless you find some way to lock it in place, such as with the JD mower lockup kit). Whereas, if you just have the regular lift off the three-point, it won't leak down.
The other downside is that it is more stuff to be removed in order to install the backhoe. For me, the independent lift option was not something I needed or wanted. Might work for you though.
I don't think I would have anything on the 3 pt while mowing anyway so it does not seem like it would benefit me in any way. I guess if you were carrying something on the back then it could be an issue.....
   / Took the plunge, Finally!!! #9
Hi Tom.....congrats on your new tractor. I also just bought a new 2520 last fall, and was somewhat confused about the independent lift vs mechanical lift deal. One salesman, (at a dealership where I didn't end up buying) was very adamant that the independent lift was the only way to go. He didn't even ask what I wanted to do with the tractor, just insisted that I needed it. Probably because it would have resulted in it being a higher dollar sale.
Glad I didn't listen to him. Unless you are going to really need, or see the need down the road, to have the ability operate the 3pth totally independent from the mower lifting action, you don't need it.
If you do have the independent lift, and want to have full control of your loader and deck at the same time, you have to buy the add on remote SCV outlet which gives you another 2 hydraulic outlets so you can keep all the loader lines and lift cylinder all connected. In addition you will need to buy the SCV control valve, so you can switch the fluid flow between the loader ports and the deck cylinder. If you don't go this route, you will have to manually switch out 2 of the lines from the loader circuit to operate the mower lift, and back again when you want full control of the loader again.
As runner has said, it seems that the independent lift will leak down, which to me would seem to be a real PITA especially after paying a good buck for it.
One thing you should consider though is that when your mower is off, and you are using another implement, the mowers lift arms will also go up and down with the 3pth. The only time at the moment when my deck is off, I have my front blade and ballast box on the rear. In order to keep the deck lift arms up, I bought the JD deck lockup kit. The kit is a little pricey (in my case in Canada it was $175) considering what it is, just a couple of brackets and adjustable chains, but it works. Some guys just use bungee cords or big zip ties, to do the job, but I'm happy with the JD kit despite the cost.
I know there are some cases where one would want independent control of the 3PTH and the mower deck, (like if you want to run your rear tiller and still keep the deck on) but in most cases I would expect if I had an implement on the 3pth, I would take the mower deck offl. The drive over decks go on and off in a couple of minutes. Then I can just hook up the lockup kit chains and the mower deck arms are out of the way, and I have full control of the 3PTH.
REV
Thanks! I don't think I would have the FEL on while cutting anyway, it will be hard enough to navigate my yard without it, but I'm sure I will get used to it in time. It sure don't seem like I would benifit in any way from that independent lift! Trying to decide now if I want to get an offset, tilting rear blade before the transaction is done.... I will see what kind of price he can work out!
MURRAY 22" GAS PUSH MOWER (A51248)
MURRAY 22" GAS...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
FAKE (A52472)
FAKE (A52472)
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
2015 CATERPILLAR 323FL EXCAVATOR (A51246)
2015 CATERPILLAR...
JOHN DEERE Q820M LOT IDENTIFIER 229 (A53084)
JOHN DEERE Q820M...
