Mowing too warm
   / too warm #1
upsetray
Bronze Member
Salem , NY
(2 Units) Bolens Iseki H-1502
I have owned my H-1502 since new and has been stored inside . When mowing ,if ambient temperature is 90degrees ,my light will come on ,usually I have to return to shop to blow out radiator and tranny cooler ,. That helps but wondered if everyone else experiences the same over heating in warm weather. How do you deal with it ?
   / too warm #2
How would I deal with it - - - hmmmmm....... I'd blow out the radiator and tranny cooler BEFORE starting the work day. Might help to drain and flush the cooling system with a system cleaning solution also.
   / too warm #3
Does it have fan belt??? check see if loose or needs replacement.
   / too warm #4
You might try testing the light switch and see what temp it turns the light on. Maybe you don't have a serious heating problem but a temp switch problem.
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
TOOLBOX/FUEL TANK COMBO (A50854)
TOOLBOX/FUEL TANK...
ABB Rotterdam Air Compressor (A49461)
ABB Rotterdam Air...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
1997 TRAILMOBILE 48X96 FLATBED TRAILER (A50854)
1997 TRAILMOBILE...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
