Too Soon Old, Too Late Smart
   / Too Soon Old, Too Late Smart #1
bsekf
WNY
Kubota 7030, Long Landtrac 4700, Mahindra 5155
My new/old 7030 sometimes starts hard. I've thought starter not fast enough, bad battery, bad connections, bad glo plugs. BUT, the last few times I have tried to start the tractor I've left the throttle very low, about 500 rpm's, and it starts right up. Did I stupidly veer into the proper procedure for my tractor or is that the correct way to start a diesel? Or, does it indicate a problem? I've always set the throttle about half way, 1000 rpm's, before starting. Have I been doing it wrong all these years?
Bill
   / Too Soon Old, Too Late Smart #2
i always start at idle rpm, around 800. certainly wouldn't want to start @ 1/2 throttle in the winter months. actually anytime. let the oil seek out it's job 1st before higher rpm
   / Too Soon Old, Too Late Smart #3
I can't say I've ever throttled up my diesels before starting them; I can't tell you of any possible effects from that, I've just never done it. 🤷🏻‍♂️
   / Too Soon Old, Too Late Smart #4
Interesting. On my new Bobcat with Deadong engine, no matter where I put the throttle lever, the tractor starts at idle. I actually have to move it up/down a cycle to even get it to throttle up when I am ready to go.
   / Too Soon Old, Too Late Smart #5
Always start at idle unless I forgot to set the throttle back when I shut it down (rare)
   / Too Soon Old, Too Late Smart #6
Bill
As with any mechanically injected engine, you always start it with the throttle set at base idle because the pump internally will advance the fuel to 100% on start up and instantly reduce it back to base idle when it starts. How they work. Electronically injected engines (common rail) are different I'm sure.
   / Too Soon Old, Too Late Smart #7
I own 4 Kubotas -- 3 older B2150 4 cyl and one BX2200 3 cyl. None of them reduce back to idle once they start. They go straight to whatever I have the throttle set at. Have not tried it on the larger MF2660 yet.
   / Too Soon Old, Too Late Smart #8
on the flip side of a work detail, i'll always let it idle a few minutes before shutdown. mainly for turbo, but a good practice anyway on agri or small engines, etc.
   / Too Soon Old, Too Late Smart #9
The start procedure in the operator's manual for my Kubota L3901 states to "set the hand-throttle-lever to about 1/2 way."
It also states to slow the engine to idle before turning the engine off.
   / Too Soon Old, Too Late Smart #10
Same in the manual for the L4701.
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
FUEL TANK/TOOL BOX COMBO (A50854)
FUEL TANK/TOOL BOX...
2000 PETERBILT 379 FLATBED TRUCK (INOPERABLE) (A50854)
2000 PETERBILT 379...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
2012 FREIGHTLINER M2 TANDEM AXLE DUMP TRUCK WITH A SNOW PLOW (A51222)
2012 FREIGHTLINER...
(3) 15X8 RIG MATS (A50854)
(3) 15X8 RIG MATS...
