Too much tractor, too little, or just buyer's remorse
   / Too much tractor, too little, or just buyer's remorse #1
waynemb3
Louisiana
JD x324
I know I am likely to get laughed right out of here, but any serious opinions would be greatl appreciated. I am brand new to lawn/garden tractors and this was the first one I ever purchased.
I recently moved to a new, larger property where I have about an acre to mow. After doing what I thought was adequate research, I went to the local JD dealer to look at a 100 series tractor. While there the salesperson talked to me about the differences between the 100 series and the 300 series, such as a beefier frame, transmission, warranty, etc. After waiting a couple of weeks and doing some more research, I was then torn between a 300 series and a ZTR. Ultimately I decided on an x324 for maneuverability and for what I thought would be a heavier duty tractor to use for other purposes.
I took delivery of the x324 a few days ago and I am dissapointed in the cut. It seems uneven and I really think the 4WS is the reason. The tractor never really holds a straight line and, in addition to the increased effort to keep it so, it produces an uneven cut. Perhaps this could be my inexperience with the machine.
Also, in doing even more research, I now wonder about the long term utility of the x324. While 99% of what I will be using a tractor for is mowing, spreading, aerating, and light towing, I could possibly foresee needing to do some gardening in the future and might need a tiller among other things. Of course the step up to a 500 series is another two thousand and, again, I may never need to do any ground engaging tasks but the possibility is not zero.
Then again if all I am going to be doing is mowing, then perhaps I should have stuck to my original plan and gotten a 100 series. In many ways it seems the 300 series is just a glorified 100 series with a lengthier warranty. I am not sure the extra money I spent is really worth it considering that the mowers' abilities are really no different despite the supposed differences between the 100 and 300 series.
In any case, I could just be experiencing a case of buyer's remorse, but I am still within my 30 day window to return the unit for something else. If I do, should I go up to a 500 series or down to a 100 series and save some money.
Again thanks for any input.
   / Too much tractor, too little, or just buyer's remorse #2
If your not happy, take it back. There is nothing worse than not being satisfied with a new purchase. I'd move up to the 500 or go ZTR.
My 2 cents.
   / Too much tractor, too little, or just buyer's remorse #3
Agree. The first week should bring a smile to your face. If it doesn't, take it back. It's just a machine.
   / Too much tractor, too little, or just buyer's remorse #5
Yep. Since you are already unhappy. You will never be happy. Take it back today!
   / Too much tractor, too little, or just buyer's remorse #6
Ditto the other posts. Find something you really like while you still can.
   / Too much tractor, too little, or just buyer's remorse #7
The 100 series is a low-budget tractor intended for sale in the big box stores, so it's main purpose is to compete on price. IMHO, you are getting a very worthwhile upgrade when moving to a 300 series -- it's a better tractor with a better design and should give more years of service.
If the 300 is not cutting it for mowing (no pun intended), what makes you think the 500 will be any better at mowing? Or even a 700? Try to figure what it is about the 300 that is causing the problem, and how the 500 or 700 will fix that before you take the plunge. Otherwise this could be a repeat performance. Generally, the more capable a tractor is at other tasks, the less optimized it will be for mowing.
About 10 years ago, I bought a Deere LT that is equivalent to a modern X500. It's been great and mows fine, but I definitely outgrew its capabilities over the years and pushed it a bit. In retrospect, if I was going to rewind and do it over, I'd go for a 700 series and know it could cover all bases for typical mowing, yardwork, landscaping, and gardening.
   / Too much tractor, too little, or just buyer's remorse #8
I would take it back. Ask the dealer to let you demo before you buy.
Do you have a need for ZTR? Why did you go with AWS?
I would not get the 100 series. And 700 series seems overkill for 1 acre. It would be another 300 series (maybe two wheel steer?) or a 500 series.
Good luck with your next pick.
   / Too much tractor, too little, or just buyer's remorse #9
Lot's of experienced voices here... sayin' the same thing! If you're not happy now - head the problem off - before it costs you!
Figure out if an upgrade to a X500 is a way to address your concerns or if the ZTR is the better way to go.
Although, I'd be hard pressed to think that the X500 would mow alot differently than your current X324! But... you can get it with a 3pt for future rototilling, etc.
No, 3pt on the ZTR, though. So, the two machines you've decided to look at have different capabilities.
Great recommendation to do a trial run if possible on the different platforms.
AKfish
   / Too much tractor, too little, or just buyer's remorse #10
I've been told that a ZTR with a 7iron mower deck gives about the best cut there is.
New/Unused 75in Skid Steer Soil Conditioner (A51573)
New/Unused 75in...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
2012 Caterpillar AT1055E Track Asphalt Paver (A51691)
2012 Caterpillar...
2021 KOMATSU D39PX-24 CRAWLER DOZER (A51246)
2021 KOMATSU...
