Too much hyd fluid?
/ Too much hyd fluid? #1
bones1
Platinum Member
St.Marys County. Maryland/Tall Timbers Md.
Farmtrac 300 dtc
Can too much hydraulic fluid in the reservoir cause the boom cylinders to leak at the seals?This probably ranks right up there on my dumb question list but I wonder if it could over pressurize the cylinders to the point of leaking on a new machine.I check my hydraulic fluid every time I use the tractor because both boom cylinders are leaking since I bought it,29 hours now,and on the dipstick it is still way past the full mark.I keep checking it waiting to add fluid but it always reads past full.This is how the tractor was delivered.Maybe I bought the perpetual reservoir option and don't know it.Any thoughts.
Just looking for a reason why my new ,clean,un-scarred boom cylinders are leaking.
/ Too much hyd fluid? #2
About the only thing too much fluid can do is cause foaming and or air in the system. Leaking cylinder seals are usually caused by wear (not your case) or improper assembly. Too high of hydraulic pressure will cause seal failure and I believe that's what you are encountering.
In as much as I don't know what brand of tractor you have I can't ascertain the static pressure, but usually, pressure in the excess of 2500 psi is too much.
I presume it's a new unit so I think I'd return it to the dealer and tell 'em to get it right or don't bring it back.:D
/ Too much hyd fluid? #3
I agree with 5030.. I don't think a slightly overfull resv. is the issue. in fact.. i own at least 3 pieces of equipment that state that the hyd sump level is filled with 'X' quarts.. but can hold 'Y' extra quarts to make up for hyd implements.. this is on my ford 5000, NH 7610s, and ford 660.
Soundguy
/ Too much hyd fluid? #4
This brings up an interesting point - and I'm not sure if it has been addressed elsewhere in TBN (my apologies to the guys who can search and find that out) - but, what is the rule of thumb for "overfilling" your hyd units? For example, I've had situations where both dealer service and my maintenance (using the manuals) have consistently delivered overfill measurements on my Hyd dipstick on my JD4600. I've asked the dealer about it and he said that it isn't an issue - as long as it isn't TOO far over and TOO far under, you're ok. I've tried to work within the limits of the dipstick (removing the overage) - but in any situation I've never had issues with leaks, etc., being a problem.
Call it luck - or maybe just tolerances not being issue... but is there a rule of thumb out there?
-Bob
/ Too much hyd fluid? #5
-Bob
Here is what i do... I don't like any of my sumps to be 'underfull'.. because in many cases.. your sump is rated for a certain capacity so the oil can cool.. not just because of the flow rate.
I fill my sumps to full mark.. let them settle, and then check for full. Then I use any aux hyds I have.. that is.. I extend loader bucket cyls, lift cyls, and any remote cyls. Then I check my oil.. typically it is a few quarts low then.. I refill to full, let settle, then check full again.. Then i relaxe all cyls... then I check the sump again.. It will typically now show a tad overfull.. I then take a small file or awl, and scratch a line at this new full level so next time i know where to fill it too.
On my NH 7610s, the manual actually gives an amount of oil, in quarts that you can overfill it to make up for aux hyds.. i forget the number.. but it is substantial.. though less than half of the 48 qt sump that is already there.
There is one caveat to that advice. On my old ford's that have a common sump, and not a seperate hyd sump.. I don't overfill... the axle seals and tranny input shaft seal tend to leak.. even when 'new' if oil is left to pool around them... Besides.. the sump on an 8n holds 5 gallons of diffy/tranny/hyd oil anyway.. and there are very few aux hyds use on the 8n/9n/2n anyway... And if you do.. you usually use an extrnal resvior and a pto or crank mounted pump.. etc.
Soundguy
/ Too much hyd fluid? #6
Well, I don't know if that's the same on the JD4600 that I have - but I've been checking regularly (after heavy use, cold, etc.) and it has never gone above or below the full line (or just a tad under it - on these dipsticks it's a shaded range that they want you to be within.
I guess I'm ok - but I find it quite odd that there can be that much give/take on the dipstick (vs. being an exact reading). I'm sure you could say the same is true for cars/trucks/etc. too.
oh well!
-Bob
/ Too much hyd fluid? #7
Though not always a hard and fast rule, generally, tractor designers plan ahead for oil being used for remotes, loaders, and any other such common activities on a tractor. That may not have always been, but nowdays, hardy a tractor is built that doesn't get SOME SORT of hydraulic add on.
Never go under the full mark. There's usually a safe margin where any reasonable hydraulic add on won't overtax the system. But it's safe as can be to over-fill somewhat. (Unless you have leaks that get worse with more oil, but that should be fixed in a perfect world.)
I generally add about 10% extra when doing hydraulic oil changes.
One thing to keep in mind regarding hydraulic oil, remotes, and cleanliness. Quick couplers are WONDERFUL. But they offer dirt a golden opportunity to get in your hydraulic system. Make sure they're clean before coupling (and UN-coupling too) The filters and screens may catch it, but why take any chances.
/ Too much hyd fluid? #8
Why not just drain the fluid out until it is at the right level? If overfilling the reservoir was the right thing to do, then why would the engineers put a max/min level on the dipstick?
When my tractor arrived, my reservoir was overfilled. I drained 1 gallon from the reservoir and the fluid is now at the max level. One extra gallon in a 11.1 gallon system may only be 9% over filled, but unless the owners manual states "ignore the max/min lines on the dipstick and just overfill the reservoir" I will assume the max/min lines are on the dipstick for a reason. If the dipstick had just a min line, (and they don't) then I would assume overfilling the reservoir was designed into the system by the engineers at the factory. Many reservoirs (like the rear end on my Ingersoll tractor) have a overfill plug. Same thing on my old 1970 VW manual transmissions. Fill the reservoir until fluid drains out of overfill plug. Wait until fluid stops draining. Then screw plug back into hole.
Bottom line, get some OEM fluid, drain the system to the max line on the dipstick and see if anything gets better or worse. There is no harm in having the fluid at the max line. There may be harm at having it overfilled. You have a great opportunity to fix it and found out if your leaks are the result of too much fluid. If the leak persists after the reservoir is correct, one possible cause is eliminated.
Bob
/ Too much hyd fluid? #9
Doc_Bob said:
Why not just drain the fluid out until it is at the right level? If overfilling the reservoir was the right thing to do, then why would the engineers put a max/min level on the dipstick? .
Bob
I guess you missed my post. The reason you can overfill a sump is so that you can accomodate some extra fluid for aux hyds without depleting your hyd sump below minimum levels. To do this.. you will obviously be in some state of 'overfull'. As i mentioned.. My NH 7610s has a 'full' mark onthe dipstick, and the manual states I can excede this 'full' level by some substantial amount of quarts specifically for aux hyd issues.. etc.
Soundguy
/ Too much hyd fluid? #10
Bones, painters are prone to paint the cylinder rods when the loader is painted. If the cylinder is slightly extended when painted, the paint will get under the rod seals when the cylinder is fully retracted and cause leaks. The seals will probably still need to be replaced as I've not known the paint flakes to wash out.
/ Too much hyd fluid? #11
Soundguy
I missed your post, oops! :eek:
But once the AUX hydro are "filled", why would I need to keep the reservoir over filled? Do these auxillary hydros "drain" back into the reservoir? I can see topping up a reservoir if the reservoir fills an empty aux hyd, but once the AUX hyd is filled, why would I need to keep my reservoir filled?
The only AUX hydro that I have is my FEL. My FEL is "full" and to the best of my knowledge does not drain back into the reservoir at the end of the day. So what kind of AUX hydro would yu be referring to?
Bob
PS Can't I check the reservoir when machine is running to see if reservoir is low?
"Bottom line, get some OEM fluid, drain the system to the max line on the dipstick and see if anything gets better or worse. There is no harm in having the fluid at the max line. There may be harm at having it overfilled. You have a great opportunity to fix it and found out if your leaks are the result of too much fluid. If the leak persists after the reservoir is correct, one possible cause is eliminated.
Bob "
Bob I will take your idea under advisement but from what I read here an over full reservoir won't make the loader cylinders leak.But this would be the easiest way to check it out. Wouldn't that be something if it cured the leaks.
/ Too much hyd fluid? #13
Possibly, all those remote cylinders are retracted when disconnected. Hook them up and extend them, and that sends oil to the cylinders and AWAY from sump. It doesn't take much, if any to compensate for several cylinders. As has been stated, it's SAFE (and probably BEST) to keep oil levels between Minimum and maximum marks on dipstick. On my Deere, which I'm most familiar with the hydraulics, it takes 1.2 gallons to fill FROM minimum to the maximum mark where I NORMALLY keep it (just shy of the max. mark)
/ Too much hyd fluid? #14
[/color]
What have you got to lose? Unless you have an AUX hydro that drains back into the reservoir every time you shut down, how can it hurt? I don't have any AUX hydro that drain back into the reservoir when I shut my tractor off.
I have an Ingersoll Lawn Tractor (1995) that has a hydraulic powered tiller. When tiller lines are empty, I need to top up my reservoir tank to allow for the filling of the hyd lines to the tiller. But once the tiller lines are filled, I no longer add fluid to the reservoir. My Ingersoll reservoir has a specific min/max requirement. Now, if the fluid drains out of the tiller lines, I refill the reservoir and fill the tiller lines.
I don't know what AUX HYD device/implement drains back and forth into my reservoir? Do you? What AUX HYD device causes my reservoir to go up and down based upon tractor being off or on. Do I own such a device :confused: ? I hope not. I cannot imagine the nightmare of one day I have to overfill the reservoir because I am using an implement that drains it's fluid back into the reservoir and the next day, when that implement is off for a month I have to run my reservoir above the max line for a month until I attach the implement that fills it lines and empties it lines when I use it.
But, given what I have said, I like TBN for this reason. I am glad that everyone is having this discussion. Now, I can learn how to do the right thing, be a better user and help someone in the future.
Bob
/ Too much hyd fluid? #15
Good points. I can easily check the dip stick, then run the tractor, leave my bucket extended (cylinders full), shut down the tractor, wait and check the dip stick. I can see how much the fluid has dropped.
I did not know that on some tractors. min/max is 1.2 gallon difference :eek: . Cripes, that is a lot of "buffer"!! I wonder if the FEl cylinders hold even a gallon? I will try to figure this out.
I have my reservoir sitting at just a hair above MAX when cold, on level ground and cylinders retracted on FEL. I did not try to get to just right on MAX, since draining that exact amount would drive me crazy and I would never get it right on the line (I never have such luck). I know I will get it a bit above or a bit below MAX if I tried to drain anymore. I defaulted to a bit above.
Bob
/ Too much hyd fluid? #16
I always either mask cyl rods off. or rub a 3/16 coat of grease on them before painting.. then when you retract the cyl, the painted gease just wipes off.. etc.
Paint flakes are bad for the whole system...
Soundguy
/ Too much hyd fluid? #17
Bob.. I think you are really overthinking this.
Ok.. here's some ideas to your questions. If I use remotes that are hooked to only SA cyls.. for instance.. my mower.. then I lift the mower and extend the lift rams.. and then I fold the wings and extend the wing rams.. and then i go park the mower. I will have left all that oil in the mower lines and cyls.. And my tractor rear axle sump will be low.. that amount of oil.
Just to be on the safe side.. i just re-checked my NH owners manual. My rear axle sump hold 15-16 gallons of oil... The manual says to extend all cyls, then top back off.. but to not add more than 4.8 gallons..e tc. That tells me that my sump can hold about 20 gallons max, and 15.5 or so is 'full'.. and the rest is for making up for remote use loss, if needed.
I'm wondering why you would be concerned with running around with a little extra oil in your sump when yuo are not using that aux remote implement... Unless your manual states no to.. I always like to keep my sumps full.. and If I'm leaving 1-4 gallons of oil in my mower parked back inthe pasture.. then my hyd sump sure ain't full.
One more point to contend. Hyd cy;s themselves may not hold alot of oil.. but you must figure oil volume of the lines too. For instance on my batwing, I have (2) 1/2" hardlines that run front to back on the mower, then i have 2 soft lines that run from there to my tractor remotes. From the back of the hard lines, I have a t, and each side has a sof line running to a wing cyl. from the other hard line is a soft line running to the tail wheel hyd cyl. Quick math tells me I have 43' of 1/2" hard and softline, plus the displacement of the cyls themselves... That's more than a trivial amount of oil.
Soundguy
Soundguy
Doc_Bob said:
[/color]
Bob
/ Too much hyd fluid? #18
Soundguy
Yes, you are right, I am probably overthinking it. My lack of experience drives many of my questions. There is simply no way a newbie like myself can learn all there is to know on my own. TBN (you and everyone else) are my "tractor family". My mentors so to speak. The tractor learning curve is very steep. I no idea how anyone could learn about tractors without help. TBN is my "neighbor next door" with all the experience. Thanks for taking the time to help me on all my questions.
Bob
/ Too much hyd fluid? #19
I' ve run my tractor hyd oil way over full for years. I run a 23gpm crank drive pump for loader and hoe, in addition to internal hitch pump. Your problem lies elsewhere. Maybe need to shim gland seals, if that's an option.
/ Too much hyd fluid? #20
I'd agree with most everybody else that over filling is not likely to cause the cylinders to leak.
Especially if it's been leaking since new the most likely is that the glands need to be tightened. It often takes a tool we owners aren't expected to have. Since new, the dealer should do it.
Good luck, Wm
P.S. My TLB hydraulic reservior is in the loader frame. If I overfill it (haven't done this for years) when it gets good and warm and the oil expands, I let the loader down, the vent on the fill plug is located just above my left knee. WHOOOOEEEE!!
2020 GMC AT4 CREW CAB TRUCK (A60430)
2020 GMC AT4 CREW...
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
New/Unused 2in Ratchet Strap (A61166)
New/Unused 2in...
New/Unused Quick Attach Pallet Fork Frame (A61166)
New/Unused Quick...
2016 F-250 4X4 (A56438)
2016 F-250 4X4...
