Tonneau cover compatible headache rack
   / Tonneau cover compatible headache rack #1
NS Gearhead
Nova Scotia, Canada
Deere X350
Dunno if this belongs in projects or in welding...
Picked up a tri-fold tonneau cover for cheap... I was pretty stoked until I found out I couldn't get a headache rack that would work with it. Thought about doing something that just sat in the stake pockets, but then came up with this.
Basic shape
Started with 3.5"x3.5"X3/8" angle. I know it's very heavy, but it was free.
Test #1
Amazing how much stress is left in the tubing when it's cut. Oh, it's 2" square 1/8" wall
Cutting out the other side to re-weld
Tried to get a little fancy... not sure if I like it.
I used another length of square tubing and clamps to make sure it was straight when I welded in the cap
Lots of measuring, checking angles, trimming, etc
Test fit #2
Can you see the mistake? LOL
At first I was going to weld angle iron tabs under these uprights, but decided to notch and angle them like this
2x2 screen. 3/16" round stock.
Added 4 u-bolts I had kicking around. I like the bottom ones, but not thrilled at the look of the top ones. I should have drilled two holes and sunk them in. Hopefully they don't show too badly once they're up there. I may put some seam sealer by the threads to pretty them up a bit.
That's where I'm at so far. Still have to make some light tabs, then primer and paint. So far I've got two weeks (maybe 15 hours), and $26 into this. I weighed it and she's a portly 126lbs. That's what you get when you use what you have kicking around.
   / Tonneau cover compatible headache rack #2
It looks like a fun project. Nice craftsmanship too! :thumbsup:
   / Tonneau cover compatible headache rack #3
That turned out real nice!!
The 126 pounds will help in the snow. :)
Terry
   / Tonneau cover compatible headache rack #4
I like it! :thumbsup: But I wish people would stop posting stuff like this. :D My to do project list just got one more added to the it.
Thanks alot guys! I just got put on shift, so that means 4 on 4 off.... 4 days to work on projects! :) Can't wait to see this on the truck permanent.
I must say, I kind of forgot about this. LOL Anyway, she's done and all that's left to do is wire the lights.
I'm pretty happy with it! :)
   / Tonneau cover compatible headache rack #7
Except for one minor little screwup, you do good work! Way better that what I do.
   / Tonneau cover compatible headache rack #9
Wow. Turned out really nice!
Terry
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
PRO WORKS PWFF LOT IDENTIFIER 143 (A53084)
PRO WORKS PWFF LOT...
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
2023 LandHonor RB-14-72W 72in Rock Bucket Skid Steer Attachment (A51691)
2023 LandHonor...
