Tongue weight measurement
   / Tongue weight measurement #1
Spindifferent
Central Texas
JD 3520, JD X584
Hi Folks,
Wanted to get your opinion on the importance of measuring tongue weight.
Is it common practice to actually measure the tongue weight with a scale for each load you haul, or do you just eyeball-it?
For perspective, the scenario is a relatively small truck (2013 Tacoma v6 w/tow package) that can tow up to 6500# using an 18' 7000# tandem axel car hauler trailer used for towing a relatively small tractor (JD 3520, approx. 3100#) and various implements up to 800# each. Tongue weight max is 650# for the Tacoma.
I'm trying to decide if I should invest in a tongue weight scale since I don't have a public scale easily available to me.
Thoughts?
Much Thanks!
- Spindifferent
   / Tongue weight measurement #2
Yes, I would weigh it at the hitch, with your equipment, loaded. Set your max tongue weight and measure to the ground, write this measurement on the trailer. Then you will have it for future use. You can also setup stop blocks for your tractor, so you can load it at the same spot each time. I have some metal wheel chocks with down pins on the front edge, they are placed in holes in the trailer deck. This works good if you have more than one implement. Mark each set of holes for each implement. Be sure to do all weights and measuring on a flat level surface. Also make sure your trailer is level, adjust tongue height with drop receivers.
Dave
   / Tongue weight measurement #3
I just weigh it once at the truck stop and then eye ball it.
Too little is way worse than too much tongue weight.
Chris
   / Tongue weight measurement #4
I weighed mine and then use a tape on the rear fender well for ars sag measurement.
I then add my torsion bars for my WDH and take a second measurement to see if they need to go up or down a link.
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A52377)
2008 Ford F-450...
Metal Peacock Lawn Art (A51694)
Metal Peacock Lawn...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
2012 WABASH 53x102 DRY VAN (A53426)
2012 WABASH 53x102...
