Toll where to put them
/ Toll where to put them #1
richh
upper Mich.
Kubota L4610 HST with loader
Heres a photo of the tool box mounted on the rear.
Rich
/ Toll where to put them #2
My that toolbox looks nice but those tires look alot better!! Great idea for storage looks like it came from the factory with it being a grey toolbox-slick-.
Gordon
/ Toll where to put them #3
Hi richh.
Nice clean looking tractor,but where the pictures of the rest of your Kubota./w3tcompact/icons/wink.gif
Do you have to have a triangle safety sign on the back of your tractor in which the state you live in?
Stay safe and/w3tcompact/icons/cool.gif
Thomas..NH
/ Toll where to put them #4
Rich, nice photo. I noticed the structure with the stackwood construction in the background. Did you build it? I helped my dad build a stackwood sauna years ago, but I don't see many people building that way anymore.
Thomas- well I live in Mi.up in the UP. And yes it cam with one of them their triangle's I took it off to mount the tool box but realy havent found a spot for, looked but it mite end up on the wall in the barn. Don't run my tractor down the road, maybe once in 5 yr. I think I need to check my spelling? what do you do with your toll's???/w3tcompact/icons/smile.gif
Rich
/ Toll where to put them #6
Rich - You need to air those tires down to 9 psi! Or do you already have them aired down? /w3tcompact/icons/smile.gif
Mine support 50% ballast, and 2,000 lbs. of backhoe at 9 psi, no sweat. If Michelin allowed it, I'd lower them to 7 or 8 when I wasn't using the backhoe.
Mark
Mark- well after looking at them last night I noticed that the right one is not seated all the way. Took it back this AM to the tire guy and he put in more air!! 50 LB. Didn't pop them out, but running it today for a few hrs. helped some, but the ride was not wery good. I need to get the ballast in the tires, wating on this rimguard stuff. I plan on running down to that same range 7-8 psi. What do you run the front ones at?
Rich
Re: Tool\'s where to put them
Gordon well i found a spot for the saw. check out the photo.
Rich
colors match to/w3tcompact/icons/smile.gif
/ Toll where to put them #10
Nice mount Rich The shame of it is that I'm spoiled now with a cab! But soon will loose that comfort. But I'm learning your mounting tricks because soon I will be in the same boat. How long of a bar will that mount hold? looks like the perfect place for it alot better than mounting it to the rops.
Gordon
I tryed everywhere looked and looked for hrs. to try and figuer this one out. It will fit a 22" bar, i run a 20" so it works for me .But you could make it a bit taller and fit a 24".
Rich
/ Toll where to put them #12
But, man, those are some nice looking tires! /w3tcompact/icons/smile.gif
MarkC
/ Toll where to put them #13
Re: Tool where to put them
Its not a toolbox, but I have found a convenient device to hold small things. It is a mesh bag that I had hanging on the handlebars of my DR field and brush mower. You can see it at
http://www.countryhomeproducts.com/groundsbag.html
I currenly have it tied around my SMV triangle sign, which is directly behind the seat of my 2910. I can also hang it on the back of the seat and either remove the SMV sign, or let it hang into the well behind the seat so it doesn't dangle outside the tractor. I keep gloves in there, small tools, the rear PTO cap when I have my mower connected, and miscellaneous other small items.
Glenn
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
2012 DRAGON  130BBL VACUUM TRAILER (A65643)
2012 DRAGON...
2014 FORD F-350 SUPER DUTY (A65643)
2014 FORD F-350...
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
2023 Dodge Durango AWD SUV (A64557)
2023 Dodge Durango...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
