Told you I'd get one
/ Told you I'd get one #41
Re: Told you I\'d get one
Push the spring back under the little posty thingy and see if it stays there.
Anyone else have the springs?
/ Told you I'd get one #42
</font><font color="blue" class="small">( Sometimes when I turn there is a clicking sound that reminds me of the sound of a piece of cardboard against bicycle wheel sprockets (ancient memories). Should I be concerned? )</font>
I assume you have the PT-425, as we do (been gone awhile, so I'm not up to date on things TBN). Ours sometimes makes the clicking sound too. It always has. The geroter hydraulic motors click when they are overdriven, and this may be what we are hearing. Since the front and rear motor on each side are plumbed in series, if the second motor in line is forced to turn faster than the first, it will be overdriven. This could happen in certain turning situations.
That's my theory, anyway. /forums/images/graemlins/grin.gif
I guess I should have mentioned that as soon as I saw this I pushed the spring back to vertical and now the pedals are better balanced in feel.
Too bad all my problems aren't this simple to solve.
/ Told you I'd get one #44
Mine does not and I took delivery of my 425 at the end of last year. /forums/images/graemlins/confused.gif
/ Told you I'd get one #45
Call them up and see how much the springs would cost? /forums/images/graemlins/wink.gif
/ Told you I'd get one #46
I got my 422 a couple months ago and no springs either and I want them. /forums/images/graemlins/mad.gif
/ Told you I'd get one #47
Thanks SnowRidge. I too have experienced the clicking sound, like plinking or strumming a spring under tension. It happens chiefly when I do, for example, a U-turn carrying some speed. That would result in the overdriven condition you explained. I recall that both of the PTs I tried at Tazewell did the same thing, so I never was concerned, but curious as to where the sound originated.
ElBubba , in my safety-conscious obsessive compulsive application of the parking brake every time I stopped the machine, I knew that sooner or later I was bound to forget to release it. When it happened, and I started to go forward at low speed, the engine simply stalled. The light bulb went on. I released the brake, re-started and back to work. I checked with PT Central and was reassured that since the brake is indeed a mechanical detent, the minor blunder would not harm the engine or hydraulic motors--like trying to push against an immovable object at low engine rpm's. As for your query about flipping the brake ON while going at full tilt, I would guess there would be some grinding as the pins tried to engage one of the slots between the teeth on the brake rotors. You might break some teeth on the brake rotors, but if one or both pins engaged the rotors w/o snapping off, the engine would stall, and the machine would come to a halt. I think I would reserve that action for a pucker situation, such as hurtling downhill toward a swarm of angry bees /forums/images/graemlins/shocked.gif. If you look at the inside of a front wheel you can see the bottom portion of the brake rotor. Like everything else on the PT, it is heavy cast iron. The teeth are quite large and rectangular, not spikey like a spur gear, and the gap between teeth is also rectangular.
/ Told you I'd get one #48
I guess I'm used to it now, so maybe it's not that big a deal.
I have been ripping out briars and saplings over the past three days and have not had any problems.
If I had the springs, I would try them.
/ Told you I'd get one #49
Just call Power Trac and ask for them...no charge...mine should be in the mail either today or Friday. I actually have grown accustomed to the treadles without the springs except when I make runs over rough ground...then I still have that foot bouncing effect...worse than breaking in a new horse!
/ Told you I'd get one #50
I recommend taking off one of the wheels and looking at the brake just so you know what's in there. It is interesting. I had to change a tire last fall and took pictures of everything, but(don't all yell at me at once) I neglected to post them here. /forums/images/graemlins/shocked.gif /forums/images/graemlins/blush.gif Shame on me. /forums/images/graemlins/tongue.gif
All that is there is a very think round plate with about 6 rounded slots cut into it. Kind of looks like a gear with very big teeth and spaces between them. The pins are just round rods. They pop into the next available slot when the wheel is rotated. Very simple, yet very functional. Typical of Power Trac and one of the reasons I like the machine and philosophy of the company. /forums/images/graemlins/grin.gif
/ Told you I'd get one #51
Hay Moss! Why don't you post those Pics??????
/ Told you I'd get one #52
Toothy /forums/images/graemlins/grin.gif pictures of the brake assembly are shown in the Owner's Manual, wheel assembly section.
/ Told you I'd get one #53
</font><font color="blue" class="small">( Toothy /forums/images/graemlins/grin.gif pictures of the brake assembly are shown in the Owner's Manual, wheel assembly section. )</font>
/ Told you I'd get one #54
I haven't referred to the manual in a few years /forums/images/graemlins/blush.gif /forums/images/graemlins/wink.gif
I'll try to post some pictures from home this weekend. /forums/images/graemlins/grin.gif
Case 1020 25ft Draper Head (A63118)
Case 1020 25ft...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
40' Used Container, High Cube, Single End Doors (A62679)
40' Used...
2022 John Deere X730 Lawn Mower (A63116)
2022 John Deere...
Landhonor 72" Skid Steer Power Rake (A62679)
Landhonor 72" Skid...
2022 EZ-GO ELITE...
