Toe In & Battery
/ Toe In & Battery #1
DSM
PA
Kubota BX22
I did the 100 hour oil change on my BX22, along with some other checks. I found the toe in was 3/4" rather than the 1/16" to 3/8" specified /forums/images/graemlins/ooo.gif This is the tread width at the front of the front tires compared to across the back. The back should be larger. I measured it with the lug tires installed, which made it easy to hook on a tape measure. It probably came this way, so you may want to check yours. Adjustment was easy. Also, I have a Deka battery with a large cover which sort of looks removable. I know it is supposed to be maintenance-free, but can/should this cover be removed to check the electrolyte level? I pried on it some, but it didn't move.
/ Toe In & Battery #2
<font color="blue"> I did the 100 hour oil change on my BX22, along with some other checks. I found the toe in was 3/4" rather than the 1/16" to 3/8" specified </font>
Wow! That is enough that if it was me I would double check my measurement...
Rather than use a tape measure, I prefer to use two sticks and a pen.
The sticks are shorter than the distance to be measured, and you pick two indentical places on the tire, once in front of the axle, and one behind.
Expand the sticks till they touch the front point, and use the pen to draw a line where the sticks overlap.
Do the same thing at the point behind the axle.
The distance between the two lines is the amount of toe in (or out, have to pay attention to which side the second line goes on...)
Tape measures are great, but nothing beats two sticks! /forums/images/graemlins/grin.gif
PS...I mean strips of wood that are thin and long, and have flat sides...maybe 1/4 by 3/4 inch. Sticks off that tree in the back yard are a whole lot harder to use... /forums/images/graemlins/blush.gif
/ Toe In & Battery #3
It would be more accurate to measure from rim to rim rather than tire to tire.
Guy
B7800
/ Toe In & Battery #4
The distance from the axle is important for tow in adjustment… if the factory spec is 3/8” at the rim, it could easily be ¾ “at the edge of the tire. I don’t know if all factory tractor tow in specifications are measured at rim edge or tire edge, but my WSM for L4200 states .1” to .3” at tire edge. KennyV.
/ Toe In & Battery #5
Thanks. Now I have to check mine in the am. Thanks! /forums/images/graemlins/grin.gif
/ Toe In & Battery #6
Your battery should have a sticker on it stating if the caps are removable. Many now are not.
Egon
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
JMR TREE BOOM (A61572)
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
2017 Case CX145D (A62177)
2017 Case CX145D...
Stihl MS 362C Chainsaw (A62613)
Stihl MS 362C...
1997 Duraco Dura Patcher 81DJ Towable Asphalt Patcher (A64194)
1997 Duraco Dura...
