TODAYS SEAT TIME
   / TODAYS SEAT TIME #13,721
Used the tractor as a work platform to build a "Mouser Motel".
We have a few hard working mousers who happen to be feral. Since they keep the local mice population well under control, the least I can do is keep 'em warm and dry in the winter as payback.
I bought (4) black totes at $10 each from HD. Lined an IBC tote with 2 inches of rigid foam, plus some straw for added insulation. It's anchored to a pallet for easy moving and to keep it upright.
Everything other than the four totes was re-use of material on hand, including the 2 inch foam board and the IBC liner left over from making firewood storage bins.
Now to find out if they'll use it?!View attachment 1833226View attachment 1833227
They should like that. But if they don't use it at first the mice will and then the kitties will take over.
gg
   / TODAYS SEAT TIME #13,723
Got 3 hrs seat time yesterday mowing for hire with the chain BH. Knocked it down pretty nice. Customer was happy.
   / TODAYS SEAT TIME #13,724
Well just a few minutes of seat time today but a few hours with a big hammer.
I'm going to be swapping the used tires from my Branson to the old IH 574 as they are pretty poor.
I had repaired on outer rim section on the left side a few years ago, but the right side was terrible even then so I had ordered a new outer rim for it and it's been waiting to get put on.
So in preparation of mounting the new outer rim I had to get the 8 bolts that hold the outer to the inner. I've had the tractor for 20 years and I believe that she is a 72 Model , so she's 50 years old.
I had been soaking those bolts and nuts as well as the lug nuts off and on for the last month. My cordless impact removed all the nuts fairly well, I loosened lubed and reinstalled them last week. So this morning it was only a few minutes to zip all those nuts off. Then it was close to 4 hours to drive those 8 bolts out of the wheel and install the new ones till the tires are ready to go, then I went ahead and removed all the lug nuts then put two back on to hold the rim and just a few more hammer blows the center was lose on the hub, sprayed a bunch of cleaner in to flush some of the crud out reached in and slathered a good amount of never seize on the hub and wheel center and all the studs. So pretty much most of my active day. Went and sat at the computer and ordered some wheels for the snow tires on my wifes car.
Jacked up and ready for some hammering;
Seven outer rim to center bolts replaced, one to go, plus the lug nuts have been removed and the hub and wheel flange and studs never seized.
Taken a few Tylenol a few hours ago and almost time for some more before bed time. The old carcass doesn't like a lot of hammering.
   / TODAYS SEAT TIME #13,725
Had one row of sweet cherries that is plagued by water holding clay subsoil and to make matters worse had formed into a water collecting shallow ditch. Cherry trees need well drained soil to survive so before I replant this row in spring decided to try a chisel and shape. Used my old Bush Hog 8 shank chisel (painted green at some time) and first time using the new 51” tilt ditching bucket.
   / TODAYS SEAT TIME #13,726
That's one of the reasons I built my 2 shank subsoiler. To break some hard clay I have on the olive orchard. It really helped breaking the ground so the water and nutrients can get down.
   / TODAYS SEAT TIME #13,727
Awhile back I added hydraulic oil in the MX, Guessing I added too much because I couldn't see it in the sight window? But I wondered if maybe I didn't add enough. So I put a little more in, then staring at the sight window flashlight in hand and scratching my head .. I got a stick and a tape measure.... then figured I had to have enough in there. Well that was a couple hundred hours ago and I finally thought I saw the level on the ridiculously small dim sight glass. But not sure so I finally ordered that JD hydraulic oil dye.
What a Godsend. No more squinting. No more flashlight. Now I can see that stuff from across the room. Phew.
It's the little things that bug me. :p
   / TODAYS SEAT TIME #13,728
I have two 5 gallon cans with the red stuff will
get two more cans plain no red dye to mix and
I will measure to see what happens in the sight
glass.
willy
   / TODAYS SEAT TIME #13,729
I added the JD red dye to my MX6000 about 600 hours ago. Enough remained in the tractor after the last filter and full hydraulic fluid drain & change that I didn't need to add more.
As you mentioned Mr. Scootr, It makes a night and day difference using the sight glass! Makes me wonder why the Kubota UDT2 doesn't come with some dye already added...like red off-road diesel...
   / TODAYS SEAT TIME #13,730
Nice. I just throw a couple of furniture moving blankets into some old dog beds on the top shelf in the barn for my feral cats. But it doesn't get terribly cold here in southern CA. Feral cats rock. Completely solved my 20 yr old mouse problem.
   / TODAYS SEAT TIME #13,731
Last 3 days been hauling and burning about 270 old cherry trees I had cut down and piled in rows , 2-3 hrs tomorrow I’ll be done . Got a incinerator pile of hot coals that burn the trees up as fast as I can haul them .
   / TODAYS SEAT TIME #13,733
Tonight
... Rain and snow, becoming all snow after 7pm. The snow could be heavy at times. Low around 31. Northeast wind 6 to 8 mph becoming north after midnight. Chance of precipitation is 100%. New snow accumulation of 6 to 10 inches possible
Today's seat time will be putting on the chains!
   / TODAYS SEAT TIME #13,734
Happy Thanksgiving all !
Our family get together postponed until tomorrow.
Up until yesterday weatherman said 1 to 2 inches here more to the south where the turkey dinner is. This morning our local prediction went up to 6 inches. So I went out and took the grapple off and put on the plow on. I just got in and looked again. The weather was upgraded to winter storm, 8+ inches. Just light snow and 30* now.
Looking at some old pictures I found this interesting one. Caption says - 100 feet long, 40" top, 68" butt, scaled at 9000 bf, South Bend. Wash. It must have been interesting getting that out of the woods and into the water.
gg
   / TODAYS SEAT TIME #13,735
Just as I was getting ready to put my wood in this fall, things came up and I didn't get a chance to get it in. I had the wood,IMG_20241128_163220.jpg
I just need to get it split and under cover.
With rain, then 6-10 inches of snow predicted I decided to forgo hunting and put some wood up. I was just putting the last stick on the splitter when I felt the first raindrops on my face. I have a good strong half cord on the trailer...
That will get me into the new year, and I can work the rest along.
I then swapped my grapple for the bucket.
   / TODAYS SEAT TIME #13,736
gg
We have about 7" of heavy wet stuff at the house and about 3" down at the road, still snowing lightly.
We had our Thanksgiving Dinner today, had to ferry everyone and down the driveway in my pickup. The studded snows were working good a bit of chewing on the last few trips this evening.
   / TODAYS SEAT TIME #13,737
HAPPY THANKSGIVING Y'ALL
Temp here was 40 this morning and 51 this
afternoon
willy
   / TODAYS SEAT TIME #13,738
I woke up this morning and my digital clock said 2:00. I hit the light switch as I went out to add wood to the fire... nothing. In the time it took to get out of bed, the power had gone out. There are massive outages around, so I'll be powerless for a while.
   / TODAYS SEAT TIME #13,739
Does anybody use a spinner knob on their steering wheel? My brother put one on the 2800 which was my father's, because he's tired of using his finger to spin the wheel.
I find it to be a PITA, but he likes it and it's a shared machine.
   / TODAYS SEAT TIME #13,740
I personally don’t like those spinner knobs but lots of folks do like them. There actually was a pretty long thread about them a while ago
2018 Dodge Durango Multipurpose Vehicle (MPV), 175,918 Miles, Third-Row Seating (A56438)
2018 Dodge Durango...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56438)
2023 Kubota...
case 370 glass door never installed (A56438)
case 370 glass...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
