TODAYS SEAT TIME
   / TODAYS SEAT TIME #5,691
Took off the blower and put on the FEL.
Started pulling rocks in the back yard.
Got a lot to dig out to make the lawn friendly to the mower.
   / TODAYS SEAT TIME #5,692
I call that trolling for icebergs around here! Good luck and my you rock be small! :laughing:
   / TODAYS SEAT TIME #5,693
Used the FEL to pull the well pump and lines up out of the well house so I could replace a couple galvanized pipes that were leaking. Then used the forks to replace that heavy azz concrete top when I got the plumbing finished.
Sorry but no pics. I was racing against the clock to get it fixed before the hardware closed.
   / TODAYS SEAT TIME #5,694
How many feet and how did you hold it between lifts?
   / TODAYS SEAT TIME #5,695
I used a chain to lift the pump and pipes just high enough to clear the top of the well house. I then wrapped a prusik loop around the pipes and secured them so they wouldn't fall into the well, then cut them loose from the pump. I replaced the elbows inside the shop so I could use the vise to hold the pump steady.
I could have used two prusik loops to pull all the pipe but I didn't have to.
Google "climb a rope using prusiks". That will give you and idea of what I did. They're used in rope climbing but works great to hold tight and pull on round pipe without slipping.
   / TODAYS SEAT TIME #5,698
I first fixed the camera that is aimed at my shifter, then I fixed the hydraulic scarifier bar which wasn't locking down, then I was doing a combination of grading trails while also hauling loads to one of my burn piles.
   / TODAYS SEAT TIME #5,699
Moved some more ROCKS! AAAHHHH I am over run with rocks!
Wish I had a way to sell these things, around here landscaping rocks don't sell worth anything. When I lived in Ohio they sold for good money, maybe I will take some up north and sell them when I visit from time to time.
   / TODAYS SEAT TIME #5,700
more like take them over my way to the coast. Can't find a rock here...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2018 CATERPILLAR 279D SKID STEER (A51246)
2018 CATERPILLAR...
JOHN DEERE 648R LOT NUMBER 108 (A53084)
JOHN DEERE 648R...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
PALLET OF 6' X 12' SITE FENCE (A51248)
PALLET OF 6' X 12'...
