Sigarms
Super Member
Good day at the range I hear...
I was told that this was a plastic can.
I'd just buy steel myself.
Shoot'n .30" out of a .22" size hole?Good day at the range I hear...
"Did see/hear too older men trying to put together a reloading kit..."
Nope.Shoot'n .30" out of a .22" size hole?
If I die before my wife, she'll have a good/bad moment on what I actually spent for tax stamps over the years.I suppose the tax stamp flies with the can..?
Are you looking to keep the shot away from the rifling? Maybe a shot cup intended for loading steel shotshells. Some of those are solid plastic cups (and fairly thick to protect older barrels from the steel shot). If you just want to seal the shot column away from the powder charge, you could do an "over powder" card wad, followed by a felt shot wad to cushion the shot column from the powder charge.So, I'm kinda working on what might be a crazy, stupid, or hair brained idea. I am wanting to make heavy paper .50 cal shot cups, for a CVA muzzleloader. I've seen guys shooting raw shot in rifled barrels with what I would call poor patterns. My throught is, a fairly heavy (double grocery bag maybe) full walled, maybe cork or double cardboard base wad, and say 400ish grs (11/16 to 7/8 oz) of shot, over 60-80 grs (volume) no4 or no5 shot. I would think the paper(maybe waxed for lube) would not fully engage rifling, and reduce spin dispersion? Looked some online, but not really found any info.
Gonna work on turning a brass 0.505 ID cylinder, and a 0.495 OD rod, as a kinda forming jig to make a couple shot cups.
The best Google searching I did in about 10 or 15 minutes didn't show any .50 cal commercial shot cups. The purpose of the cup is twofold; avoid fouling up the rifling with shot impacts; and also, to avoid (as much as possible) imparting the spin to the shot column, which makes it spread faster. I saw a very short description once of using basically a cheese cloth baggy of shot in rifled muzzleloaders, but I don't think they ever discussed what the end results really ended up as.Are you looking to keep the shot away from the rifling? Maybe a shot cup intended for loading steel shotshells. Some of those are solid plastic cups (and fairly thick to protect older barrels from the steel shot). If you just want to seal the shot column away from the powder charge, you could do an "over powder" card wad, followed by a felt shot wad to cushion the shot column from the powder charge.
