If you are not measuring CBTO you aren’t 15 off, OAL is just a fun to know number there’s too much variance in the shoulder of TMKs. SMKs are known to have up to 30 differences within a box.
I do know what you mean; but there are issues with CBtO measurements.
First of all, that is a measurement that only works with your comparator, and can't be reused with others.
The other issue is that Ogive measurement on the comparator isn't truly where the lands make contact with the Ogive.
And the main issue, from my stand point; with reloading you can go crazy in a dozen directions; down to bushings, expanders, uniforming primer pockets, bullet sorting, measuring bullet run out, ect ect. Its not that each doesn't actually help, but you can increase your effort/work load 50% for 5% gains pretty easily. Right now, my goal is 0.75" groups; now if I get to the point that I have multiple loads consistently doing that, im sure I will up the requirements, and push for 0.50" groups, ect.
Reloading can be a fairly cheap and simple process; and it can also be rocket science. I prefer to hang out somewhere in the middle, favoring the simple side.
As far as how I got my Max COAL; I took a fired piece of 223; resized only the Neck, cut the neck with a dremel, place a bullet in neck and seat the bullet in the case using bolt closing; pushing the bullet against the rifling to seat the bullet. I then slowly and carefully remove and check. Repeat multiple times. Cost, 1 piece of 223 brass, impact bullet puller and some of your time. My measurement with 75gr TMJ where between 2.3245 and 2.3265 over multiple checks.
