TO30 Z129 12v ignition coil query
   / TO30 Z129 12v ignition coil query #1
FergFan
Middleburg, FL
1953 Ferguson TO30 Z129
I have a TO30 Z129 that has been converted to 12v. I recently purchased a 12v ignition coil that I'm unsure is the correct part. My new coil states that an external resistor is required, which my previous coil didn't have.
This is the link to the coil I just bought
Ignition Coil, 12 Volt [S.61016] - $16.60 : Fix That Ferguson!, Tractor parts for Ferguson and Massey Ferguson tractors.
[/URL]
I've seen other coils that are priced 3 times as much..(ones with 3.0 ohms resistance and ones with .6 ohms resistance) I'm assuming these are the ones I should've purchased.I've never worked on or purchased parts for this tractor. Did I purchase a $15 coil when I should've got one for $45? These other coils say "use with inductive ignition systems"..Here is an example of what I'm considering
https://www.tractorpartsasap.com/Electronic_Ignition_Coil_p/108304.htm
Is the coil I've recently purchased usable?
2008 CATERPILLAR 430E BACKHOE (A51242)
2008 CATERPILLAR...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2006 Peterbilt 379 T/A Wet Kit Sleeper Cab Truck Tractor (A49461)
2006 Peterbilt 379...
2011 Ford Explorer Limited AWD SUV (A50324)
2011 Ford Explorer...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2001 STERLING WATER TRUCK (A51243)
2001 STERLING...
