To Thumb Or Not To Thumb?
   / To Thumb Or Not To Thumb? #1
Henro
Elite Member
Few miles north of Pgh, PA
Kubota B2910, BX2200, KX41-2V mini EX
Recently there was a thread about a kit to add a thumb to a backhoe.
The kit is not that expensive and for many cost would not be an issue. Welding it on might be for some, but for many that would not be an issue either.
For me the problem is on a tractor, with a rear mounted backhoe, I just can't imagine a thumb being that useful. On an excavator...yes, without question, has to be greater than sliced bread!
To me the advantage of the thumb would be the ability to grab things and carry them somewhere. Hard to do with my backhoe, as I got to keep changing seats to move the tractor.
Anyone have a thumb on thier tractor-mounted backhoe? How about a report on how it works for you? What percentage of the time do you use it? What do you use it for?
In my mind a grapple on the loader would be much more useful for me than a backhoe thumb...
What am I missing... /forums/images/graemlins/confused.gif
   / To Thumb Or Not To Thumb? #2
A lot of time after I dig out a stump I drag it to my dumping area with the backhoe. Since I usually have gotten out of the hole with the backhoe, it's easier to go ahead and just carry it on.
I think it would be a lot easier for me with a thumb on it as I have dropped them in transit sometimes because it's a little hard to get a good grip without one.
I also think I'd have a much easier time getting a stump out of a deep hole too. Sometimes I have to really work it to get a stump out.
I agree the grapple would probably be more useful, but I can see the thumb on my BH, and I plan to get one of those kits that I posted about in the near future. John
   / To Thumb Or Not To Thumb? #3
I second the motion. /forums/images/graemlins/wink.gif
   / To Thumb Or Not To Thumb? #4
I don't have one on mine but, I've used one on a 580L and they're handy for moving trees that you've dug up out of the way for next one. Also you can dig on one side of tree, push it over then grab tree and raise it to pull the remaining feeder roots up. Saves some time digging. Not sure if 3pt hoe would be strong enough to justify the investmrnt though. It takes a lot of power to pull a tree up by roots.
   / To Thumb Or Not To Thumb? #5
I’ve been looking into one for my backhoe. What I want to do is use it for harvesting firewood. I think it will be helpful for loading 6-8’ long log sections onto the dump truck and when unloading use it to hold the log off the ground while cutting to their final length. They would also be great for building rock walls.
MarkV
   / To Thumb Or Not To Thumb? #6
I don't have a thumb on my BH and I really don't want one. I don't think using it to move a stump or tree is a good choice since your load would now be behind you while maneuvering the tractor to where you wanted to dump them. We all know how fast things can get out of hand with a tractor. /forums/images/graemlins/shocked.gif I have had loads in my FEL that I needed to dump really quick because of an unstable condition. That would not be possible with a thumb.
A grapple might be a lot safer to use for moving stumps and trees IMHO. I say "thumbs down" to the addition, at least for me.
   / To Thumb Or Not To Thumb? #7
</font><font color="blue" class="small">( I don't think using it to move a stump or tree is a good choice since your load would now be behind you while maneuvering the tractor to where you wanted to dump them. )</font>
I should have said that I keep the loader filled with concrete blocks when doing this for good ballast.
I live on mostly flat land, and ALWAYS go slow. I've never had to drop the loader in an unstable situation, but it can sure happen. I've had no problmes using the BH to move stumps, keeping it down pretty low to the ground for heavy loads.
Yes, I agree the grapple may be safer, with ballast on the back as well. John
   / To Thumb Or Not To Thumb? #8
The only time I REALLY wish I had one was when I put in about 200ft. of rockery. I could use the loader to get the rocks to where they had to go, but I had to hand stack each rock. Some of those rocks must have weighed 400lbs. ( at least) and I had to lift them by hand. /forums/images/graemlins/wink.gif ..... Ok, maybe 100lbs.......But still, at my age they were dang heavy. Besides that, I bought my tractor so I WOULDN'T have to lift things. With a thumb, I would have been able to lift from a pile and place them. I looked briefly at them before the project, but I was under the impression that any welding on the Kubota BH would void the warranty. Is there any truth in that?
Greg
   / To Thumb Or Not To Thumb? #9
I'm thinking I wouldn't use one that much. The getting on and off my Deere to change from BH seat to tractor seat would get old in a hurry, I think.
A grapple on the front end loader would be more to my liking but a lot more money. I'd think even something fixed like the BH thumb (obviously larger and set wider) attached to the loader arms somehow would be something I'd be more likely to use.
   / To Thumb Or Not To Thumb? #10
Here is a picture of picking up a rock to remove a wall. I moved these rocks away from the construction area and saved them to rebuild the wall later.
I have rented an excavator and used it to build a 110' two stack high boulder retaining wall. I first removed an existing boulder wall. I then hired an excavation company to lengthen and widen the driveway and cut a building pad at the end of the driveway. I then rented the excavator again and transported even more rocks back and set them in place. After a while I was able to place the boulders quite accurately.
I've decided that a thumb on my backhoe may be of limited utility. I tried to move a tree in the backhoe and it was unstable enough to convince me that transporting heavy items in the tractor backhoe wouldn't work.
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51692)
iDrive TDS-2010H...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
2001 Ford Expedition SUV (A51694)
2001 Ford...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2021 KENWORTH W900 TANDEM AXLE SLEEPER (A54607)
2021 KENWORTH W900...
