To Paint Farm Fences or Not?
   / To Paint Farm Fences or Not? #11
That is interesting and I have a similar situation here with paint. A few years ago I had a company paint my garage roof. It was in good condition just a little dull white. They used expensive Sherwin Williams products and in less than a year roof looks like it does now! The metal edges are even rusty (I'd have to get ladder & show from above). I had them paint walk-in door frames which you see are rotting.
Maybe something to do with paint today vs what they used years ago.(?).View attachment 3257430View attachment 3257431
IMPO, the brick mold door trim appears to be finger jointed material which isn't very rot resistant. You could replace it with PVC trim.
   / To Paint Farm Fences or Not? #12
Latex paint is plastic. If you wrap wood in plastic it had better be plumb dry and stay that way otherwise it's going to do what wood does when it's wrapped in plastic. Traditional oil paints and lime washes will breath and dry out through the paint, by latex by and large doesn't.
   / To Paint Farm Fences or Not? #13
This a common misconception, and for homes it is very important latex paint allows the outward movement of water vapor (vapor permeable), otherwise the material behind the latex would mold. While it is true that latex is a polymer, it is as or more permeable to water vapor as oil paint. More information below;
All the best,
Peter
   / To Paint Farm Fences or Not? #14
I'm sorry that the paint job has not held up the way that one would expect.
If it were me, I would be having a discussion with the painters. Paint preparation is 90% of the job in my experience. I painted to put myself through school, and have always been interested in paint chemistry and coatings.
Sadly, I think that if it were me, I would be replacing your door trim at this point, and hoping that the door frame can be repaired. There are "Dry-rot" epoxies to solidify rotted wood, but if the water is getting in higher up, that won't help. Is there standing water at the door when it rains? As to the algae, I use "Wet-n-Forget". I would try that on your roof to see if it improves things. If it doesn't, I tend to reach for more potent cleaners. Was this an issue before it was painted as well? E.g. a north slope that never gets sunshine?
Take the following with a grain of salt as they say. I'm a Sherwin-Williams advocate, based on decades of experience with their paint and others. I do use other brands. We currently have Sherwin-Williams paint on the house and outbuildings and 90% off it is in good condition 19 years later. The material that isn't 100% is on surfaces where the underlying material is failing, or has failed, so not really the fault of the top layer. (Think 100 year old paint on 100+ year old wood that was repainted 19 years ago with a new layer.) Preparation is 90%...
However, Sherwin-Williams makes an enormous range of paint and paint quality. Here the low end paint is in the $35/gal price range, and the high end residential paint is in the $140/gal range. I believe that the high end paint is better. Is it 4X better? That's a tough call. I might use it on a house that I plan to be in for twenty years. Perhaps not if I only need the paint to last three years. I might use the pricier paint on areas that had access issues, e.g. multistory building, where the labor and equipment cost to get painters up in the air adds to the job cost. Commercial quality paints for special applications can be even more expensive.
However, great paint on an inadequately prepared surface is just wasting money and resources. Even a great paint needs a clean, strong, intact surface to adhere to. Sometimes, that is sanding, priming, second coat of primer, and a top coat or multiple top coats. If I am spraying, I always back roll with a roller to get the top coat into all the crevices. I think of spraying as a way to get paint onto a surface and rolling or brushing the paint as a way to get the paint into the surface. I never just spray latex paints, but that's just my personal opinion. I am more in the do it once and forget it category.
Sherwin-Williams makes a line of paint that is "self-cleaning" exterior paint called "Rain refresh" because the paint generates a cleaner from sunlight and water that dissolves off dirt sticking to the paint. ($$$, $130/gal locally) Obviously, it works better in areas that get rain periodically, and rather unusually it has a UV protecting agent that doesn't break down in sunlight. Those two items have benefits to an owner, and some geeky chemistry behind it.
All the best,
Peter
Peter has given a great summary on painting in general (and yes, I painted my way through school, too).
Water is always your enemy - let it inside next to the wood and rot (mold organisms) begins to eat away the wood substrate, releasing the paint cover. If hiring someone, the first question to ask is, "How will you prepare this job?" Painting is never as hard physically as a good prep job - that's pure hard work and few will do it right.
If the guy doesn't know what a bonding primer is...walk away. If he doesn't know how to stop rust oxidation with the proper products prior to painting...walk away. If he says he can easily repair/heal damaged interior trim (used in an exterior application) with caulk...walk away. Yes, epoxys and fiber strengthening solutions can sometimes work, but the cost, time, and skills required complicate that approach. And I've done it. You quickly are in the realm of autobody repair with those products.
I never skimp on cost for paint. As Peter notes, Sherwin Williams makes cheaper paints and excellent paints. Choose wisely. There are specialty paints as well, but that's not needed here. But a conversation with a major paint store manager is often warranted. He or she will be pleased you asked and a few pictures and some input on the job at hand goes a long way. He will also know who the good guys in town are. That's particularly important today. EPA regs (please, no politics here) mandated major changes in the fine oil based paints we used to use - hybrids are now what are being used to reduce outgassing and it took a while for the major players to get that right(er). A Benjamin Moore store will have excellent products in its pricy top tiers. Another in the East is Porter Paints, but they were bought by PPG so I guess I don't know as much as I used to (funny how that works). And though I always will want the old oil based stuff, good latex products have really impressed me lately. But, make sure a recommended bonding primer is used between any oil and latex transition...
As Peter noted, the damage to the trim and the exterior location might suggest replacement with a composite product. But read the specs carefully - wood is fairly stable in length, but composites are not. Be aware of how much they change in length due to temps and use exactly the caulk, glue, nails, and procedures recommended by the manufacturer.
I'll second the "Wet and Forget" mold/mildew treatment if needed. I use it on some damp areas of brick and stone. It works, but you will have to re-apply occasionally. Getting rid of the moisture would be better...
Painting fences...no good answer for looks. There are houses in New England that had clapboard siding that lasted for hundreds of years without painting. But, we do like the look of a white fence... So, cut the posts on a slant, don't put a vertical face plank over your joints at the post, and try to heavily dress the top of the post with paint to protect the relatively untreated core of the post. Buy posts from a supplier that will provide a certification of how much "treat" is in his posts. And every 35 years re-do some of your fence (like I had to do last year...). Amazingly, my wife did not want to help with that job like she would do in earlier times... The best white fence paint I have found (and I'm in KY) is "Town and Ranch," now a division of Farrell Calhoun. I don't spray - just feel brushes and rollers get the paint where I want it to go better. Oh, and don't paint the underside of the fence planks - just holds water and no one sees it anyway.
Best of luck
   / To Paint Farm Fences or Not? #15
All the best,
Peter
The painting company supposedly is one of the very best in my area. They spent two days with prep, pressure washed then used etching primer, primer, paint. I photographed materials and sent pictures to my Palm Springs friend who's brother is a paint contractor giving Bill Gates as a reference since his company painted his house. He said materials used were the top best. It was expensive and of course beautiful when finished.
I did complain and owner came back redoing everything once again. It didn't take long to look like crap. The original contractor said those panels are powder coated baked on and has never heard of a satisfactory painting on them.
If I live long enough and if necessary I'll just have a new metal roof installed.
   / To Paint Farm Fences or Not? #16
The fence paint that I bought and never used is specifically marketed for painting fences. I'd be surprised if it causes fences to rot.
I'm not aware of any prep work for painting a fence, but perhaps a local fence company would be nice enough to share insights?
Just a theory here - if your posts have flat tops and you get rain the paint may help hold moisture in the posts instead of allowing them to dry naturally. I cut the tops of posts at about a fifteen degree angle to prevent standing water.
All of these were cut at an angle for that very reason.
Interesting observation...
Are there any other variables at play? Maybe change in drainage of front vs back of property, standing water, different soil types?
Nope. In fact, the posts that are painted and rotting are up hill from the ones that are not painted and are solid, and the painted ones get a LOT more sunshine.
I really think the paint is rotting the posts from the inside out. Just out of curiosity I walked over to my neighbor's field and looked at her posts. Not painted, installed 25 years ago, and still pretty solid. Hmm...
2018 Freightliner M2 106 Lay Flat Roll Back Truck (A55852)
2018 Freightliner...
CATALOG UPDATES LOT NUMBER 5 (A53084)
CATALOG UPDATES...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
2016 Godwin CD150M...
EZ-GO Golf Cart (A55853)
EZ-GO Golf Cart...
2019 CATERPILLAR 336GC EXCAVATOR (A52706)
2019 CATERPILLAR...
Kubota ZG327 (A50120)
