To Load or Not to Load (FEL question)
   / To Load or Not to Load (FEL question) #1
mstewart44
Hello All, newbie here with 1st post. I'm about to pull the trigger on a 2007 JD 5103 with a Rhino TW72 mower and a Brown 6' disc. The salesman asked me if I wanted the 512 FEL that goes with that tractor. I've waffled back and forth about it and still can't decide. Looking for feedback from those of you with a FEL and how much you use it. Cost of the FEL installed is $4500. JC Credit currently has 0% for 60 months on the 2007 03 series tractors (since the model lineup is about to change) and I can get the FEL financed on the deal. I have 160 acres of hunting property just south of Macon, GA that is 10 ac food plots, 2 to 3 miles of roads and firebreaks, 50 acres of 11 y.o pines, 50 acres of 2 y.o pines, and 50 acres of hardwoods. I could see usig the loader to push stuff around and out of the way like tree limbs and tree tops, etc, but don't know if it is a good purchase. Any help out there??
   / To Load or Not to Load (FEL question) #2
NO question ... get a FEL at any cost. I use it at least as much as any implement on the back - probably more. Hopefully you'll get a quick attach on that FEL ... makes it even more valuable.
   / To Load or Not to Load (FEL question) #3
I second that. Plus that loader has the Deere "quick-change" feature.... you can swap from bucket to pallet forks, to whatever in about two seconds. You will not regret the purchase.
~Paul
   / To Load or Not to Load (FEL question) #4
Go for the loader--you will be amazed at the things that you find it useful for. I would think tha tyou could load everything you need for new foodplots in the loader--go off and get to work with the supplies travelling with you etc etc
   / To Load or Not to Load (FEL question) #5
A FEL will about double the usefulness of your tractor... given the size of your place, etc. I think you will find that you engage the FEL over 50% of the time that you take your tractor out for a spin. Get a toothbar at the start as well, since it about doubles the usefulness of the FEL itself.
   / To Load or Not to Load (FEL question) #6
If it isn't clear enough to you yet - GET THE FEL!!!!! If you don't, you'll be wishing you did in 6 months, and then it will cost more. You'll have to transport the machine back to the dealer for install...
   / To Load or Not to Load (FEL question) #7
Absolutely, 100%, get the FEL. I've just never understood why anyone would buy a tractor without one. If for nothing else, one day you'll use the FEL to unload items from your truck, like that heavy mower deck or some 300' roll of fencing.
   / To Load or Not to Load (FEL question) #8
I didn't Know they made FELs with out tractors, or what good is a FEL without a tractor?
   / To Load or Not to Load (FEL question) #10
I have to agree with the consensus.. with that much land to care for.. get a loader... By the way.. loaders haul out dead animal carcasses pretty good (wink)
Soundguy
2004 Ditch Witch RT70M Ride On Trencher (A53117)
2004 Ditch Witch...
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
Unused 2025 Electric Cart (A51694)
Unused 2025...
Lawnmower Jack (A53117)
Lawnmower Jack...
2010 Nissan Sentra Sedan (A51694)
2010 Nissan Sentra...
