To hot to handle
   / To hot to handle #1
Stacy Millis
alberta. canada
Kioti DK55C
I have a DK55c with 38 hours on it and when I use my woods 6 ft. mower for an hour or so the rear housing around pto shaft gets pretty hot. when checked it was around 170 degrees. Everything works fine no abnomal noise. But I personely think that is to hot. Just was wondering if anybody out there ever had the same problem or if anybody has an idea about what temp. it should run at. Thanks.
   / To hot to handle #2
I have a dk55c. I have never checked the temp but i would think that the housing would reflect the temp of the hydraulic oil inside the transmission case. It would probably be in that range when being used. I have used a much bigger shredder on mine with no trouble so far. You could check the temp of the case down lower to see if it was close to the same numbers.
   / To hot to handle #3
When mowing with my ck30 I monitor the temp of two things. The engine coolant with the gauge and the trans fluid temp by placing my hand on the trans filter which is reachable from the operator station. I hold my hand on teh filter and if I can leave it there for three full seconds then it is fine. If not, I have a plugged cooler and need to open it up. The trans fluid gets hot.
170 is colder than the engine coolant so likely not in the too hot range with regards to seals.
   / To hot to handle
Thanks for your replies. I was just concernd if might mean a more major problem. But so far it has not gave me any problems so I will just wait and see. I will see what I get when I change the oil.
2012 KENWORTH T370 PROPANE TRANSPORTATION TRUCK (A52472)
2012 KENWORTH T370...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
2012 FREIGHTLINER CASCADIA (A52472)
2012 FREIGHTLINER...
JLG 1255 Telehandler (A52748)
JLG 1255...
2020 FORD F-250 SUPER DUTY (A52472)
2020 FORD F-250...
