to buy or not to buy - b6000E
   / to buy or not to buy - b6000E
another question - how many gears does it have and do you have to cluch and brake and stop before changing gear or can you do it on the move ect...
see i said i had alot of questions and not a clue
seriously though - tell me if i ask too much
thanks /forums/images/graemlins/grin.gif
   / to buy or not to buy - b6000E #32
<font color="green">does it have a diff lock? </font>
Yes I does, it is the pedal almost directly under the seat. I find I use the brakes just to stop the spinning wheel most of the time. The diff lock can give you a pretty scary ride some times.
Gary
   / to buy or not to buy - b6000E #33
<font color="green">how many gears does it have and do you have to cluch and brake and stop before changing gear or can you do it on the move ect... </font>
3 forward and one reverse, with a hi / lo range = 6 forward and 2 reverse. I have shifted gears within a range and have shifted from lo to hi range, but it never really feels as smooth as I would like, so I ussually stop first. I think it is strong enough to take it though!
Gary
am i right in saying there are 2 pedals on the left - 2 on the right and an accelerator on the right
the two on the left are the two wheel brakes and one of the right hand pedals is the clutch - what is the other one on the right or doesnt it exist/there isnt one
if you cant be bothered or dont want to answer i wont be offended if you dont - i dont want to stop you doing anything else
thanks i appreciate it
   / to buy or not to buy - b6000E #35
One other thing...
Most of my shifting is either from 3rd gear lo range to 1st gear hi range so there is no easy way to make that shift. On level ground a normal 1st to 2nd to 3rd is not a problem.
Don't worry about the questions I am happy to help. And it seems like there are many others here who feel the same.
Gary
   / to buy or not to buy - b6000E #36
The clutch is on the left, and the two brakes are on the right. The throttle is hand operated on the right side of the hood / bonnet!
The only other peddle is the diff lock located almost under the seat.
Don't worry about the questions Mith.... I am just waiting for the snow to stop so I can go out and plow!!!!!!
Gary
on the one i just bought there is a hand throttle b yhte side of the hood and a small almost button like pedal underneath the clutch which is a throttle - i guess yours doesnt have that then
i know that is a throttle cos he used it to revv it up
can you lock the wo brakes together to make them brake equally or is your foot supposed to span them?
how fast does it go 3rd high, 5mph, 10, 15?
do you have much snow?
thanks for answering these its very helpful to me /forums/images/graemlins/grin.gif
   / to buy or not to buy - b6000E #38
<font color="green"> can you lock the wo brakes together to make them brake equally or is your foot supposed to span them? </font>
Mine has a metal bar that can drop between the two peddles to lock them together. I rarely use it though... bit of a pain. Even my small feet have no problem stepping on both! I do find once every other year or so I have to adjust them so they are at the same hieght. I tend to use the left brake more for tight turns when I am cutting the fields.
<font color="green">how fast does it go 3rd high, 5mph, 10, 15? </font>
I was going to say maybe 10mph, but I took a look at the manual and it says:
B6000
6th 7.2 mph
Iterestingly is shows the B6000E
1st 1.12 mph
2nd 1.81
2rd 2.88
4th 5.12
5th 7.77
6th 12.04
Looks like you got the fast one!!!!!
<font color="green">do you have much snow? </font>
We are just getting the NW edge of the storm. Maybe 3 - 4" Lots of wind that is blowing it around along with the 12" or so we have had in the last week. Mostly just drifting, light, easy to move snow. It looks like they are getting pounded in SE Maine.
Gary
just saw on the news actually - snow storms in US causing havoc at airports, doubt well get any snow here in the UK this year /forums/images/graemlins/frown.gif
check it out though - 12 mph on a tractor!!?? crazy /forums/images/graemlins/crazy.gif
i see what you mean with the gap from 3rd to 4th - its like 2-3 mph
ah well thanks for all the info, when i get it ill have a load more questions most likely
thanks for your help
ok nother question for everybody
does the PTO shaft on a b6000 turn faster than that on other tractors
i found a PTO converter bit it looks as thogh there is a ratio on it - if i am to make one i need to kno the ratio
can anyone help
attached is a picture of it
2016 Chevrolet Colorado Pickup Truck (A50323)
2016 Chevrolet...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2017 Dodge Grand Caravan SE Van (A50324)
2017 Dodge Grand...
2025 12V Diesel Pump and Hose (A50323)
2025 12V Diesel...
Mower King Q.A Pallet Forks (A50121)
Mower King Q.A...
2013 Ford F-150 Ext. Cab Pickup Truck (A50323)
2013 Ford F-150...
