Rotary Cutter To buy a rotary mower ( bush hog) or not?
   / To buy a rotary mower ( bush hog) or not? #1
Sniggle
Jefferson County, WV
2003 Kubota B7800 (new to me @ 435 hours
I am going to have 4 acres of pasture to mow. I have a 60 inch deck for the B7800, and I guess I could use this to mow the pasture (I used my G1900 to mow it last year once the gras got going). This would save money.
I could also get a 5 foot rotary mower, and leave the deck in the barn. This would allow me t quickley transition to jobs that might be hard with the deck attached.
What do you all think?
   / To buy a rotary mower ( bush hog) or not? #2
It depends on what your 4 acres are like. If it's nice and smooth and no saplings, stumps, or roots, then a finish mower could do the job.
However, if it is rough, you are likely to damage a finish mower. Brush mowers (e.g. "Bush Hogs") are made to run into things and keep going.
Ken
   / To buy a rotary mower ( bush hog) or not? #3
4 acres isn't allot of mowing. Spending money on another type of mower, the same size as the one you already have, that will give you a rougher cut, doesn't make any sense to me. Since you can mow it with your deck, then it's not so rough that you need a rotary cutter. The advantage to the rotary cutter is that it can handle taller, thicker and out of control fields.
Saying that, if you let your 4 acres get out of control, or only plan to mow it twice a year, then a rotary cutter makes more sense. If you plan on mowing once a month, then the finish mower should be all that you need.
Eddie
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2013 Chevrolet Impala Sedan (A55853)
2013 Chevrolet...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
Portable Restroom (A54865)
Portable Restroom...
