To buy 425 or 1430-that is the question?
   / To buy 425 or 1430-that is the question? #11
Do the attachments for the 425 fit the 1430?
   / To buy 425 or 1430-that is the question? #13
While it would not be a big deal to make up an "adapter-adapter" plate to facilitate attaching 425 attachments to a 1430, another ?bigger issue is the hydraulic flow mismatch between the 425 (8GPM) and the 1430 (12 GPM). That might be a problem for some implements.
   / To buy 425 or 1430-that is the question? #14
I think the adapter-adapter would work, but the extra power behind the 1430 might damage the 425 attachements. The hydraulic problem is easier to fix, you do a bypass line so that some of the flow goes around the attachment. I wish someone would try this. I might buy a 1430 in five years if it works out.
Bob Rip
   / To buy 425 or 1430-that is the question? #15
<font color="red"> you do a bypass line so that some of the flow goes around the attachment. I wish someone would try this</font>
At the time I bought my PT 1845 PT sold a hydraulic bypass system for the fertilizer spreader that had a moter rated for the hydraulic flow of the 425. The bypass system allowed the spreader to be used on the 1430/1845.
I ultimately opted for an electricly powered fertilizer spreader sold by Earthway--It was less than half the price of the PT unit and utilized a plastic bin rather than steel used by PT--an advantage when working with corrosive materials like fertilizer.
   / To buy 425 or 1430-that is the question? #16
How do you like the Earthway spreader? I saw an electric one at Northern Tools that sounds similar. I wonder if anyone has experience with it on a PT.
Bob Rip
   / To buy 425 or 1430-that is the question? #17
I have been satisfied with the Earthway spreader. It holds a 50 lb (15,000 square foot) bag of fertilizer and the electric motor works fine for the spreading action. The on/off is via a lanyard that controls a spring loaded plate.
Earthway makes the same model with stainless motor housing and metal parts for a lot more money but I bought the standard painted steel version. I have had mine for three seasons and with washing after each use corrosion has not been an issue.
The model I bought has a 2in trialer hitch mount adapter available so I purchased a quick attach plate and had a 2 in receiver welded on.
The Earthway spreader comes with a cigarette lighter plug so I installed a cigarett lighter outlet below the dash that can also be used for other electric supply purposes.
   / To buy 425 or 1430-that is the question? #18
To answer your original question.
I own a 425, I think it is plenty of tractor for our 5 acres. I also own a 1/2 ton 2wd F150, I don't need 3/4 ton or 4wd in a truck. So based on this you may realize I don't like to waste my money on things/extras I don't need. I think the 425 will do everything I need it to do now and for the short term to mid term future as well. That's why I got it instead of the 1430. The only complaint I have with mine is I don't get to use it enough. /forums/images/graemlins/tongue.gif
   / To buy 425 or 1430-that is the question? #19
I have a 1430 and tow it with a 18 ' carmate trailer with a single wheel f-350. Pt Rich put his 425 in a pick up bed. but I like the 1430 because of the diesel, size, gpm . I use it commercially that why I went with larger model. I put turf tires on it and it went pretty well in the winter. I also used chains but sometimes they would slip off and I would not notice and take out the inside valve stem on the tire . But when I have a tire malfunction I take it off the rim and weld 2nd valve stem hole shut . When it thawed in january I worked in a sheep field and got around decent but I think every machine has it limitations. on tearing up turf in normal conditions it doesn't, the 1430 does not tear up turf only if i really force the machine it only burns the grass I have never driven a 425 but the 1430 get into preety tight spots
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2013 John Deere 27D Mini Excavator (A55973)
2013 John Deere...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A56435)
2023 Kubota Z412KW...
2020 DRAGON ESP...
2013 Ford Edge (A54815)
2013 Ford Edge...
2004 AGCO Gleaner 3000 Corn Header (A56436)
2004 AGCO Gleaner...
