TO-35 Deluxe Standard Diesel 23C cooling system question
   / TO-35 Deluxe Standard Diesel 23C cooling system question #1
Boomer2
Silverton, Oregon
Massey Ferguson TO-35 Diesel
I have a 1957 TO-35 Deluxe with the Standard diesel engine. I'm trying to clean out the cooling system and don't see a block drain anywhere. Does anyone have a picture or schematic of the where the plug would be if there is one? I've looked through the shop manual and the web for any help. If there isn't a drain plug how do you all rinse out the block? My radiator doesn't have a drain plug either, so I have removed the lower hose to drain and rinse the radiator.
   / TO-35 Deluxe Standard Diesel 23C cooling system question #2
My Standard diesel doesn't have a block drain either but does have a radiator drain, but a bought a replacement radiator several years back. Not sure about OEM radiators. If yours is the OEM radiator, it has lasted a LONG time. Thankfully pulling the bottom hose isn't too difficult. Why are you cleaning the system? Overheating? If so, I'd suggest you take your radiator to a radiator shop and have the do a flow test.
1993 Ford F700 Stakebody Flatbed Truck (A51692)
1993 Ford F700...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A55302)
2019 New Holland...
UNUSED DIGGIT 72" HYD MULCHING HEAD (A54757)
UNUSED DIGGIT 72"...
2019 John Deere XUV560E Utility Cart (A55787)
2019 John Deere...
2003 John Deere 310SG (A47477)
2003 John Deere...
8' LARGE FENCE POSTS (APPROX. 20-25 PC) (A54757)
8' LARGE FENCE...
