TO-35 Deluxe Standard Diesel 23C cooling system question
   / TO-35 Deluxe Standard Diesel 23C cooling system question #1
Boomer2
Silverton, Oregon
Massey Ferguson TO-35 Diesel
I have a 1957 TO-35 Deluxe with the Standard diesel engine. I'm trying to clean out the cooling system and don't see a block drain anywhere. Does anyone have a picture or schematic of the where the plug would be if there is one? I've looked through the shop manual and the web for any help. If there isn't a drain plug how do you all rinse out the block? My radiator doesn't have a drain plug either, so I have removed the lower hose to drain and rinse the radiator.
   / TO-35 Deluxe Standard Diesel 23C cooling system question #2
My Standard diesel doesn't have a block drain either but does have a radiator drain, but a bought a replacement radiator several years back. Not sure about OEM radiators. If yours is the OEM radiator, it has lasted a LONG time. Thankfully pulling the bottom hose isn't too difficult. Why are you cleaning the system? Overheating? If so, I'd suggest you take your radiator to a radiator shop and have the do a flow test.
1983 Case 580D (A47477)
1983 Case 580D...
UNUSED LANDHONOR AD-12-23C HYD AUGER (A54757)
UNUSED LANDHONOR...
2025 JMR 72in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 72in Dual...
2023 INTERNATIONAL MV607 21FT ROLLBACK (A54607)
2023 INTERNATIONAL...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A55788)
2009 Peterbilt 384...
2001 CHEVEROLET C6500 3 CAR ROLL BACK (A54607)
2001 CHEVEROLET...
