TO 30
/ TO 30 #1
rdbrumfield
Western Washington
5300 JD 4X4
I picked up this from a lady that needed some work done around her place. It had been sitting for 2 yrs and blew a front tire when I rolled it off the trailer. Well, after a new tire and tube, checking lubes, cleaning points and some fresh gas it fired right up. I remember the one I used as a kid, it brought a lot of memories back and sounded so sweet. It had a loader on it, which I immediately took off. It is totally self contained with the pump and hydraulics built into the frame. If anyone wants it give me a note. This one is a Harris Ferguson. I didn't know that they made one with that name.
/ TO 30
It sure is. Thank you for the correction. I had to look. I never heard of that name before. I have heard of the ferguson and massey ferguson, but not the harry ferguson.
/ TO 30 #4
Ferguson & Massey Harris were combined to make Massey Ferguson, the Ferguson 3-point hitch system is still being used on the AGCO built Masseys today.
Chuck M.
/ TO 30 #5
That tractor has many interchangeable parts with the 8N ford, especially
the 3ph parts. the engine is probably a "Continental" - made in Detroit
parts are still readily available. ..Good Luck (see attached )
/ TO 30 #6
My TO-30 has this badge on the nose. Does yours?
/ TO 30
Yes, it does RayBee. About the only things it needs, are the side crome by the rear of the hood, the lower lift links have been repaired, a top link, and a new steering wheel. The rest of it just needs cleaned up and given a nice coat of paint. Yours sure looks nice.
/ TO 30
I might add that the serial no plate is under the steering wheel and has the Harry Ferguson logo.
/ TO 30 #9
Great old equipment. Fergison in the one that invented the 3 point I think and ford had a deal to get the three point and ford fergisons were born, then fergison went with harris etc. You can still get many of the parts for those tractors new from either the ford or the massy shop.
I just got done resoring a to 35 for a bud of mine. they actualy have quite a few advatages over the fords of the same day.
Dane
/ TO 30 #10
nice set up. Dop you use the buzz saw?
/ TO 30 #11
I had a TO 30 Ferg once, for about 10 years. I 'tolerated' the 3pt on it (preferred the 8N Ford) because it didn't have position control. Either going up or going down. It did have a good draft control, if I remember right.
I always thought something was broken that the position control would not work. But learned when I tore it down that there was nothing inside that would feed the height of the arms back to the control valve. So, I made do and learned to live with it. When I 'moved up' to a Deere 420 two-cyl, I gave up some hp, but gained the position control in the 3pt, and had draft control too.
I really liked the TO 30 and hope you like yours as well.
/ TO 30 #12
Higgy: .... Yes ,I do cut firewood with the Ferguson (see attached).
It's nervous work, but have done it many years.
/ TO 30 #13
gonads /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif
Dane
/ TO 30 #14
rdbrumfield: ...Thanks, I've owned her for about 25 yrs. and the paint is showing some wear, but still OK if it's clean. I think these are what you'll be looking for.( see attached )
/ TO 30
yes, that is exactly what I need. Hope to find some as I would like to get back up to looking new
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
(2) Wheel Spacers w/Caps (A64127)
(2) Wheel Spacers...
TYE 118-610 5 Shank Ripper (A63688)
TYE 118-610 5...
6' Bush Hog (A62613)
2024 Ford Explorer AWD SUV (A61574)
2024 Ford Explorer...
