TNA Wheel track settings urgent!
   / TNA Wheel track settings urgent! #1
hotchkiss
Ohio
JD 6330, JD 5055e, Ford 4000,
I am looking for a way to access the wheel track settings for the TNA series tractors. Another member sent me a link to the T4000 series materials that provide the settings for those tractors. I assume the TNA is similar but need to double check. Thanks.
   / TNA Wheel track settings urgent! #2
There should be no difference between the TN wheels and the T4000 as they are the same tractor but with different decals.
   / TNA Wheel track settings urgent! #3
Are they really to be unchanged? I had heard that the 3-cyl engines were no more, to be replaced with slightly larger displacement 4-cyl in the TN60 and 75 replacements? Probably for Tier 3 emissions?
With all due respect, they are not the "same" tractor. They are very similar, and you are correct in that they no longer have the 3 cylinder engines. Perhaps, Robert was referring to the frame of the tractor. If so, I believe he is correct, but was wanting to double check other sources.
   / TNA Wheel track settings urgent! #5
Yes, there are actual changes but nothing major to the frame. The basic tractor is the same as is the wheels and settings. From the outside the only noticable difference is the decal on the hood.
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
ATTENTION PLEASE READ (A50123)
ATTENTION PLEASE...
2011 Ford F-350 Enclosed Service Truck (A51692)
2011 Ford F-350...
Bobcat 14" Hydraulic Asphalt Plainer (A52384)
Bobcat 14"...
2013 Ford F-550 Passenger Bus (A51692)
2013 Ford F-550...
2017 Chevrolet Silverado 3500 HD Crew Cab KUV Enclosed Service Truck (A52377)
2017 Chevrolet...
