TNA Wheel track settings urgent!
   / TNA Wheel track settings urgent! #1
hotchkiss
Ohio
JD 6330, JD 5055e, Ford 4000,
I am looking for a way to access the wheel track settings for the TNA series tractors. Another member sent me a link to the T4000 series materials that provide the settings for those tractors. I assume the TNA is similar but need to double check. Thanks.
   / TNA Wheel track settings urgent! #2
There should be no difference between the TN wheels and the T4000 as they are the same tractor but with different decals.
   / TNA Wheel track settings urgent! #3
Are they really to be unchanged? I had heard that the 3-cyl engines were no more, to be replaced with slightly larger displacement 4-cyl in the TN60 and 75 replacements? Probably for Tier 3 emissions?
With all due respect, they are not the "same" tractor. They are very similar, and you are correct in that they no longer have the 3 cylinder engines. Perhaps, Robert was referring to the frame of the tractor. If so, I believe he is correct, but was wanting to double check other sources.
   / TNA Wheel track settings urgent! #5
Yes, there are actual changes but nothing major to the frame. The basic tractor is the same as is the wheels and settings. From the outside the only noticable difference is the decal on the hood.
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
(5) GOLF CART CANOPIES (A51248)
(5) GOLF CART...
PALLET OF MILITARY STRAPS (A51248)
PALLET OF MILITARY...
(4) 6 LUG GMC TIRES & WHEELS (A51248)
(4) 6 LUG GMC...
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
UNUSED WOLVERINE BC-13-72W-72" HYD BRUSH CUTTER (A51248)
UNUSED WOLVERINE...
