TN95 and TN85
   / TN95 and TN85 #1
hotchkiss
Ohio
JD 6330, JD 5055e, Ford 4000,
Does anyone know the size of the allen socket that is needed to remove the drain plug for the oil on this size tractor. I went to change the oil this weekend and didn't have the right size. But I only had a half inch with me in the larger size wrenches.
   / TN95 and TN85 #4
Isn't that supposed to come with the tractor? A nice little common tool kit for them is supposed to be in the tool box I have bee told by one dealer. Mine had the allen wrench but nothing else. I looked in a bunch of other new tractors on the lot yesterday and all their boxes were empty.
things I recommend carrying is that 12 MM
10 mm combination wrench. (bleed screws)
13 mm combination wrench (for switching your spool valve int eh back from single acting to double acting)
15 mm combination wrench (loose banjo fittings)
17 mm combination wrench (injectors)
flat heat screwdriver both small and large ones.
   / TN95 and TN85 #6
All TN oilpan drains as well as the 4WD planetary hub drain/fill/checks. Most, if not all TL/35 series, too.
   / TN95 and TN85
Thanks. 12mm it is then.
   / TN95 and TN85 #8
You don't actually think dealers leave stuff like that in tractors sitting on the lot, do you? It sure wouldn't stay there long.
Put a 22MM wrench on your list so you can check the oil in the front axle center section.
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2014 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2014 Great Dane...
20 ft Angle Boom (A53117)
20 ft Angle Boom...
2011 CATERPILLAR 140M2 MOTORGRADER (A51246)
2011 CATERPILLAR...
2025 CFG Industrial H15R (A50123)
2025 CFG...
2004 Wabash National 28ft Van Trailer (A51692)
2004 Wabash...
