TN75s errore cod 13
   / TN75s errore cod 13 #1
Liga
San Martino in Rio
New Holland
Hi, i have error code 13 on my new holland tn75s. What is it?
Thanks
   / TN75s errore cod 13 #2
There are 2 error code 13's. One is the 4wd engagement circuit.....it says 4wd is permanently engaged....causes 1. short circuit to ground 2. Solenoid terminals disconnected 3. naked wire. The other is "Hi-Lo P. buttons"....activated when they are pressed simultaneously....causes 1. both pressed simultaneously 2. Lo-P button pressed and high locked 3. Hi-P button pressed and Lo locked....This is a problem with the power shuttle. What year is your tn75s? Mine is an '02 and the manual I have is for 98 to 03 models. I hope this helps. Let us know. I bought the manuals after I had error code 33 for a couple of years....dealership no help. Turned out to be a faulty tilt sensor which was easily identified using the manual.
Ok, thank you. I have a problem with 4wd. I have to check all cable and terminal.
My tn is '99
Thanks
   / TN75s errore cod 13 #4
You are welcome. Let us know what you find!
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
2011 MERCEDES-BENZ E-Class Sedan (A56859)
2011 MERCEDES-BENZ...
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
2014 PETERBILT 388 VACUUM TRUCK (A55745)
2014 PETERBILT 388...
JOHN DEERE LAWN SWEEPER (A58374)
JOHN DEERE LAWN...
2022 Ram 2500 (A55973)
