TN75da won't pull
   / TN75da won't pull #1
elkhurst1
Clay, WV
NH tn75da & tn55
Hello all,
Last week I had to use myTN75da to jumpstart another tractor. After doing so and maybe a coincidence, the tractor will stop pulling and the transmission light will come on.
I can put the shuttle lever back to neutral, and then back to forward or reverse and it will pull for a few seconds, but then stop pulling again. There are no codes coming up from the ECM either!
Does anyone have any ideas where to start looking?
   / TN75da won't pull #2
No clue but you might try disconnecting the negative terminal of the battery for a while. I would think that that would reset the computer. I'm not sure who your local dealer is, but if you give Knight's in Glen Easton a call, they have a couple of fairly savvy mechanics. Most dealers in our area lost their mechanics to the oil field.
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A55315)
2023 New Holland...
2008 Ford F-550 4x4 Rugby Mason Dump Truck (A55852)
2008 Ford F-550...
UNUSED FUTURE SGB20 20" HYD STUMP GRAB BUCKET (A57193)
UNUSED FUTURE...
Case Maxxum 140 (A50120)
Case Maxxum 140...
Man Basket Forklift Attachment (A55851)
Man Basket...
UNUSED JCT 72" HYD BRUSH CUTTER (A57193)
UNUSED JCT 72" HYD...
