TN75DA Hydraulic pump change (Which one)
   / TN75DA Hydraulic pump change (Which one) #1
KYTIMM
Somerset
TN75DA
Hello everybody,
The hydraulic pump on my TN75DA is out. Power Steering is operational. I have ordered the new pump and ready install. The dual pumps on the tractor look identical from the outside. Does anybody know which pump is for the hydraulics?
The pumps are on the right side of the tractor, and when standing on that side they are facing front to back.
   / TN75DA Hydraulic pump change (Which one) #2
The aux hydraulic pump is in front of the timing cover. Did you order the correct pump? There are choices.
Don't know Rick. I ordered the one that's in the book. Got the part number from Messicks. Both pumps are on the right side of the engine, one facing foward, one facing backward.
   / TN75DA Hydraulic pump change (Which one) #4
Well if the pump was not ordered with regard to determining if your tractor is equipped with a 12 or 16 GPM pump you are rolling the dice. I would expect if Messicks gave you the part number that you supplied them with your tractor serial number.
Yes I did. Its a 16. Which one is the loader and lift pump?
   / TN75DA Hydraulic pump change (Which one) #7
May I ask what type of hyd diagnostics were performed to determine that hyd pump had failed?
Over the many yrs I have been associated with tractors I have witnessed & read about many hyd pumps being replaced only to determine that the replaced hyd pump was not the problem.
2014 Ford Escape SE, Eco Boost (A52384)
2014 Ford Escape...
(2) 24" W X 5 1/2L HEAVY DUTY FOLD UP TRAILER RAMP (A51247)
(2) 24" W X 5 1/2L...
(7) STABILIZER JACKS (A51248)
(7) STABILIZER...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
40' shipping container (A52377)
40' shipping...
2021 JOHN DEERE 8R340 LOT NUMBER 193 (A53084)
2021 JOHN DEERE...
