TN75DA Error Code 47?
   / TN75DA Error Code 47? #1
ezslim
Central Virginia
FarmPro 2430, New Holland T5070
Hi Gang,
Anyone know what error code 47 means? Tractor is driving fine, but throws the code while mowing hillsides. Sorry to say the local dealer won't give me the answer. I imagine he'd like the service call instead.
Thanks in advance,
Slim
   / TN75DA Error Code 47? #2
"Clutch Pedal Switch too High". In order for the PowerShuttle transmission to work properly, there has to be a specific relationship between the clutch pedal switch and the clutch pedal potentiometer. The pot controls clutch feathering and gives you that dry clutch engagement feel, along with a big spring. The switch controls the dump valve solenoid providing positive loss of drive and is also part of the neutral safety start circuit. That relationship is a little outside of optimum at present. As noted, the tractor works fine. Next time the tractor needs dealer attention, have the switch adjusted and the fault cleared. If other symptoms develop, get them addressed.
Thanks Rick,
I appreciate your response very much.
Slim
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2015 John Deere 8295R (A50123)
2015 John Deere...
Gravely Compact Pro Zero Turn Mower (A53117)
Gravely Compact...
2016 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2016 Great Dane...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A53473)
GOODYEAR SET OF...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
