TN75DA Clutch job.
   / TN75DA Clutch job. #1
Jabonee
Platinum Member
Pennsylvania
Mahindra
Greetings. Got a friend that wants me to do some repairs on his tractor including a new clutch. Anyone out there that has done the clutch?? I'm trying to find out what I'm up against before I take on the job. Unit has a cab. Will it need to be removed to split the tractor?? I have a full shop at my disposal and have done many tractor clutches. This will be my first blue one.:confused:
   / TN75DA Clutch job. #2
Not real difficult. New Holland suggests removing the cab, which does make it easy to split. But you can also remove the front cab bolts, loosen the rear mounts, remove the appropriate linkages and tilt up about 5 or 6". Unfortunately, it is still a little cramped getting to the bolts on the top of the bell housing, but it can be done.
2020 Caterpillar 259D3 Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2002 TRAVIS BODY & TRAILER, INC. 48 END DUMP TRAILER (A58214)
2002 TRAVIS BODY &...
Bobcat Forks and Frame Skid Steer Attachment (A56857)
Bobcat Forks and...
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
