tn75 would not start
   / tn75 would not start #1
fastlx
We have a tn75 with the pto light on & does not start!
when we play with the pto lever it did start a couple of time but today we could not anny more
Is there a switch somewhere for this light or how can we have a wiring diagram to fix ..
we need it badly know my sun as snoww removal contract & it started to snow again today just when it dicied not to start !!!
   / tn75 would not start #2
Rick will most likely tell you in more detail but if the pto light is on the computer will not let the tractor start as it thinks the pto is engaged. The safety switch most likely went bad and will need to be replaced but to start the tractor now you can jump across the terminals on the starter solenoid (just make sure the tractor is in neutral). I have done this a few times when I was stranded and had to get the tractor started. It isn't recommended and is not something you will want to do every time you need to start the tractor but it will start the tractor in an emergency. Just take the plastic cover off the solenoid on the starter and jump across two of the terminals (I can't recall which two right off hand without going to look but if I recall there were three terminals).
Yes we did that this afternoon but the problem is that it started & we had a couple of lghts on & did not want to move fwd or rev...
maybee the computer for some reason does not like we we jump the starter !!!
Where is this switch i was thinking just for a couples of days to jump this switch !! until i buy one & snow stops so i can replace it
Thanks for your help !!
   / tn75 would not start #5
Do you have the power shuttle?
Yes why ?
   / tn75 would not start #7
Power shuttles are a different beast and have more electronics then mechanical shuttles like mine. I can't advise you any more as I have very little experience with the power shuttle TN75. Hopefully Rick will pop in soon to help. You can also go to New Hollands website or www.messicks.com and view parts diagrams for your particular tractor. It might help you and you can order the parts direct from Messicks site as it shows if they have the part in stock and its price all up front so its very convienient and easy.
   / tn75 would not start #8
There is the potential you may have damaged the computer on your power shuttle jumping the solenoid. Hopefully you didn't but it would make me nervous.
   / tn75 would not start #9
Please describe where your PTO control lever is. The location of the lever helps locate the PTO NSS that isn't functioning properly.
Yes for sure it is not but i have no idea where this switch is !
The pto lever is on the right aft of the throttle !!
2019 Ford F-350 4x4 Ext. Cab Palfinger PSC 3216 4,000lb 2 Ton Mechanics Crane Service Truck (A50323)
2019 Ford F-350...
2013 Jeep Patriot SUV (A50324)
2013 Jeep Patriot...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2010 KMC 3376 Peanut Combine (A52748)
2010 KMC 3376...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
