TN75 syncro clutch pedal spring broke
   / TN75 syncro clutch pedal spring broke #1
forbesservices
saegertown, pa
New Holland TN75
Today my tractor clutch pedel spring broke. I've tried searching for how to repair - mainly where it hooks up and how to get in there to work on it - but haven't found anything. Anyone ever break one? And what is the easiest way to fix it? Do I need to take the dash out? Any help would be appreciated.
The spring is about 3 inches long - eye balling it. I'm sure it isn't that expensive, I'm confused as to where the other end hooks up since I can't get my large mellon under there far enough to see anything. I really don't want to have to tear everything apart just to put a spring on. Currently the tractor is sitting in my driveway with the forks under something on my trailer.
If it is a big job to fix, I'll have to put it in neutral and tow it out and down to the barn...
   / TN75 syncro clutch pedal spring broke #2
I have the same issue. Did you resolve? Does anyone know the answer?
   / TN75 syncro clutch pedal spring broke #3
Welcome to TBN. I have taken the spring off when doing a clutch replacement, but don’t think it is diffic to get back on. I may have just used Vice Grips to get back in place.
   / TN75 syncro clutch pedal spring broke #4
I had one break on my Ford-New Holland 7740 bout 20 years ago while out snowblowing. Needed it fixed in a hurry , found a real close match at the local hardware . Stretched it in with a pair of vise grips in about 10 seconds and worked fine. I ordered a new one from New Holland but just kept it as a spare. I can’t imagine yours is much more difficult, should be pretty obvious hole or hook at the stationary end. If you’re having a hard time seeing under there a mirror or better yet lighted mechanics mirror should let you see where it hooks too.
Duetz Power Unit (A50120)
Duetz Power Unit...
2011 New Holland Boomer 90 MFWD Utility Tractor (A55301)
2011 New Holland...
2008 JCB 520-40 TELESCOPIC FORKLIFT (A51406)
2008 JCB 520-40...
1988 Kenworth W900B Dump Truck with 3406B CAT (A55218)
1988 Kenworth...
