Oil & Fuel Tn75 Smokes and uses oil
   / Tn75 Smokes and uses oil #1
dalethomure
Our 2002 Tn75, since the last oil change, has started to produce a lot of white to white/blue smoke at lower rpms and seems to use more oil than what is normal. It would always use approx. 1 qt between services, but now can use a qt. after two days of bale handling and raking.
No oil in the water or water in the oil. We primarily use this tractor as our chore tractor all winter and use it to handle bales and rake inthe summer.
We replaced the turbo last year as it was leaking oil.
Could it be an injection or air intake problem ?
Any thoughts about the culprit are appreciated.
   / Tn75 Smokes and uses oil #2
White smoke sounds like unburned fuel. Check the injectors and the pump.
We found the problem. Bad Turbo.
   / Tn75 Smokes and uses oil #4
What's the cost to fix/replace the turbo?
   / Tn75 Smokes and uses oil #5
Why is that thing going through turbos. 2 turbos in two years is ridiculous. Are you putting on new or remaned?
Bill
2017 Ford F-250 Service Truck (A56858)
2017 Ford F-250...
2015 Ford Explorer (A56859)
2015 Ford Explorer...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
Mini Skid-Steer 4-in-1 Bucket (New/Unused) (A59225)
Mini Skid-Steer...
2018 JLG 742 TELESCOPIC FORKLIFT (A52709)
2018 JLG 742...
