TN75 Hydraulics
   / TN75 Hydraulics #1
tomnytractors
North Central Texas
While working, suddenly lost hydraulic pressure to rear remote and 3-pt lift stopped working. No noises and plenty of fluid............any suggestions where to start?? thanks
   / TN75 Hydraulics #2
My TN75 did same thing a couple weeks ago. Thought one of the pumps went out but after talking about this issue with a dealer I bleed the hydraulics and all is ok now. It turned out to be air got in the system some how. Easy to do and just takes a few minutes. I would definitely give it a try, doesn't cost anything. If you need directions let me know.
   / TN75 Hydraulics #3
I'd 2nd that..start there first like he say doesnt cost anything...mine is usly happen first thing in the morning if havnt use in a few days...
   / TN75 Hydraulics
Update: I had looked on several discussion forums and came across one describing a similar problem, but with a different make tractor. Their solution was to park the tractor nose down on a steep grade for a couple of days and let gravity do the work. I had plans for the weekend that didn't include the tractor, so that's what I did. Sure enough, today I started it up, actuated the remote and 3-pt, and everything works fine.
Recalling what I did a few minutes before it stopped working, I was mowing on a steep tank dam; I guess it was steep enough to vent air into the hydraulic return.
   / TN75 Hydraulics #5
I have a TN75D New Holland. Please give me the instructions for bleeding the hydraulics.
Thanks
Jim Sides
1607 (A57192)
1607 (A57192)
2013 Nissan Rogue SUV (A56859)
2013 Nissan Rogue...
AUCTION STARTS HERE @ 9AM (A52709)
AUCTION STARTS...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
2019 Freightliner M2 106 Johnston VT651 8.5 Yard Street Sweeper Truck (A56858)
2019 Freightliner...
