TN70 Won’t go into gear
   / TN70 Won’t go into gear #1
Mac Daddy
NewHolland TN70
Hey guys, this is my first time ever posting on a forum but I’m at my wits end. I have a Tn70 with 3100 hrs on it. I thought the clutch had gone out of it, but it never slipped when using. Always grabbed good.Recently I was shifting from forward to reverse and it would not engaged in any gear. No forward no reverse. Finally after playing with the shifters it went into gear and worked for about a day. Then it did it again. If I played around with the shifters, I could get it to go into gear, but if I shifted travel direction, it would not go back into gear. If I let it sit a day, It seems to go into gear and move, clutch seems to grab correctly, but only till I shift to change from forward/reverse. The linkage does feel loose like it’s not engaging. Mechanic said he feels it’s in the linkage but can’t seem to find the problem. Could it still be the clutch, even though it was never slipping. The clutch pedal was releasing very high at the top. I was wandering if it could also be electrical? Any help will be so much appreciated! Thanks yall
   / TN70 Won’t go into gear #2
Nothing electrical unless it's a power shuttle. Your description of events kind of rules that out. There is one thing that comes to mind. On the mechanical shuttle tractors there have been a few issues where the roll pin securing the shuttle shift fork to it's respective shift rail has sheared. This results in very limited (or absolutely no) action internally to shift the shuttle synchronizer. The shifter and external linkage all moves as it should, you can feel the detents, the neutral switch operates, but the shift fork inside does pretty much what it wants to. To get to that roll pin is a project.
Thank you so much Harry. This sounds exactly like what has taken place. I will look into what it takes to repair that roll pin
Anyone got any links to a manual or video showing this process would be very much appreciated. Thanks guys!
   / TN70 Won’t go into gear #5
Is it a TN70A? D? S?
At least for the electric shuttle shift the clutch lever has a massive spring to make it feel like a traditional clutch. The spring is on the clutch lever and pivot assembly below the dash.
The electric shuttle shift has an orange shifter handle. I would also inspect for wiring damage (mice, corrosion, etc). The electric shuttle shift clutch has a couple of potentiometers -- adjustable resistors that change as the clutch peddle moves. Remove the panel below the left side of the dash to inspect that area.
   / TN70 Won’t go into gear #6
It's NOT a power shuttle. No wires or electric signals involved.
4 Cubic Yard Dumpster (A55851)
4 Cubic Yard...
2025 Kivel Fork and Frame Mini Skid Steer Attachment (A56857)
2025 Kivel Fork...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
John Deere Hopper Assembly Kit (A56469)
John Deere Hopper...
UNUSED PABREAK AR650 HYD AUGER (A57193)
UNUSED PABREAK...
UNUSED FUTURE FT-X39 39" HYD TRENCHER (A57193)
UNUSED FUTURE...
