TN70/75
   / TN70/75 #1
SDT
SE Indiana
Multiple Fords and Kubotas
I am considering buying a TN70 or TN75 with FWA to operate a 7 or, more likely 8, foot three-point cutter over varying terrain, some of which is quite steep. I am also considering the Kubota M6800 with FWA. Anyone have any helpful comments regarding these machines? Thanks, in advance.
Dean
   / TN70/75 #2
I own a TN 75 and use a 6' 3 pt cutter. The TN 70 or 75 should be plenty for a 7' or 8' cutter. The only comment I would have with respect to the difference between the New Holland or Kubota is weight. The New Holland's (and for that matter JD's and MF's) are quite a bit heavier than the Kubota. A 7' or 8' 3pt cutter is pretty heavy and possibly could cause some problems on hillsides. With that said, you'll probably be OK with either choice.
   / TN70/75 #3
I purchased a TN75A with a 7ft Brown HD rotary cutter. I use it on 10-15 deg slopes with no problems. If the ground is wet, make sure you keep the FWA locked in to be on the safe side. Also, varying your speed and the direction of cut makes a difference. I run perpendicular to slope of my hills (up and down) as opposed to parallel just because I feel a little more comfortable with this method, even though it is a little more work and takes more time.
I also purchased a 7ft RC because I did not want my mower extended out past the width of my rear tires. The Brown 484 is also a heavy 3PH unit at 1350lbs - you can check them out at www.brownmfgcorp.com to see additional specs.
A TN70 or TN75, will be a good choice for mowing, but consider also that the TN75 comes with higher flow hydraulic pump as std. equip. and has a few extra HP.
The decision based on cost differential when I purchased was a no brainer, but results will vary depending on dealer inventory, etc.
I also looked at the Kubota 6800 and JD5420 - the Kubota was OUT for me due to the levers being located on the floor between your legs - The 5420 was about $3k more
The power shuttle is another option you may want to seriously consider -
Hope this helps - and good luck on your purchase. /forums/images/graemlins/cool.gif
1994 PETERBILT 379 SLEEPER (A50046)
1994 PETERBILT 379...
2022 Adams CLC-1013 Conveyor - New (A51039)
2022 Adams...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
2015 FONTAINE VELOCITY 102" X 48' STEP DECK TRL (A50459)
2015 FONTAINE...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A50854)
2014 FORREST RIVER...
BREWSTER DRAWWORKS WITH TWIN CATERPILLAR ENGINES (A50854)
BREWSTER DRAWWORKS...
