TN65S Alternator / charging problem, alternator tests okay
   / TN65S Alternator / charging problem, alternator tests okay #1
bdsoper
Park City, KY
New Holland TN65S
I'm new to the forum and of course, I need some help. :)
I have a TN65S that isn't charging. The alternator tests fine but when installed back on the tractor, although the constant hot wire is hot, the key hot wire is not energized. Any ideas?
   / TN65S Alternator / charging problem, alternator tests okay #2
Welcome to TBN. :thumbsup:
Does the key switch start the tractor? What voltage reading is present at the battery when the tractor is running?
What voltage is present when the engine is cranking to start? Have you checked the chassis ground at the negative cable from the battery? Have you checked the fuse box and any relays to make sure if anything is loose, corroded, chewed by rodents?
You removed the alternator and had it bench tested? Does it have a built in voltage regulator?
LOT OF CHRISTMAS DECORATIONS (A58374)
LOT OF CHRISTMAS...
New Holland 1412 Discbine Pull Type Mower Conditioner / Windrower (A56435)
New Holland 1412...
2017 CATERPILLAR 305E2 CR EXCAVATOR (A52709)
2017 CATERPILLAR...
2014 Kaufman 12,000 Lb. Trailer, VIN: 5SHFD2223EB000633, Tandem Axle, Wood Deck, Tilt Deck, Asset# (A59076)
2014 Kaufman...
2018 DRAGON 53FT FOUR AXLE HEAVY HAUL TRAILER (A58214)
2018 DRAGON 53FT...
CASE INTERNATIONAL 4R DANISH TINE CULTIVATOR (A52708)
CASE INTERNATIONAL...
