TN65D radio
   / TN65D radio #1
FltBrokFarms
Pensacola,Fl
1974 Ford 5000,1943 John Deere A, Brand new New Holland TN65D
On a new TN65D that was not ordered with a radio but came with speakers and all the wiring,do you have to purchase from New Holland the wiring harness that fits the tractor harness to fit lets say a Sony Radio,or is there a after market item?Thanks
   / TN65D radio #2
On my TN75D which came with the same harness yours did, I purchased the New Holland harness for about $35 to get the connector and wires to mate with the tractor harness. I cut off the other end which I believe has an Audiovox set of plugs on it and used tubular splices to attach it to my Pioneer radio harness that cam with the radio. You do not need to purchase the harness but it sure made the job easier. If I did it again I would also install a headphone jack as the radio is not always that easy to hear. I'd set it up so that when the headphones are plugged in the speakers were disconnected.
Andy
   / TN65D radio #3
You could always just cut the supplied tractor side connector off as well as the radio connector. Then solder the appropraite wires and then use heat shrink tubbing to insulate the solder joints. Thats the cheap way.
Fred
2011 Cadillac DTS Sedan (A50324)
2011 Cadillac DTS...
2012 Peterbilt 337 IMT 6025 14,000lb 5 Ton Crane Mechanics Truck (A50323)
2012 Peterbilt 337...
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
2018 Wacker Neuson WL 38 (A52748)
2018 Wacker Neuson...
Scag Zero Turn (A50121)
Scag Zero Turn...
2015 Peterbilt 337 Tilt Body w/ Dovetail (A52384)
2015 Peterbilt 337...
