TN65 "accessory"?
   / TN65 "accessory"? #11
Re: TN65 \"accessory\"?
You can easily run most things off the four prong outlet. Found out the hard way mine is fused to 40 amps. Its inside the cab but appears to be the same plug. Uses an automotive spade type fuse.
Your dealer will have the other half that plugs in. Two hot wires (12V) and two grounds. Both hot wires are tied into the same fuse on my machine.
I run a baler off this plug.
Fred
2017 Wanco WSDT3-S S/A Towable Radar-Speed Trailer (A55973)
2017 Wanco WSDT3-S...
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
Gradall 53409-45 Telehandler, Turbo Diesel Engine, 45' Reach, Rear Steer, 60" Forks, 6,699 Hours (A59076)
Gradall 53409-45...
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
CORN SHELLER MOUNTED ON WOOD BOX (A58374)
CORN SHELLER...
2019 Harley Davidson (A56859)
2019 Harley...
