RandySmith
First post ... so hello everyone !
The fuel injector pump on this tractor was leaking like a sieve around the large O-ring around the distributor head. Removed injector pump, and distributor head and installed a new O-ring. Re-assembled what I believe is the exact way we took apart.
Unfortunately, after re-assembly multiple times and multiple orientations of the plunger shaft we cannot get the engine to crank. Notch on the plunger and pin are aligned to the "key" for the timing gear. We did not touch or disassemble the adjustment for the timing, unfortunately I do not have a dial indicator to measure the 1mm of movement that is suggested in maintenance manual. I was hoping this pump could be reassembled without complicating life by touching that, and just by only replacing O-ring inside the pump. The pump was marked and re-aligned to same mark. Pump gear #4 aligns with #4 on cam gear with flywheel at PMS position. There is 12v going to the fuel shutoff solenoid when toggling the keyswitch on/off. There is fuel squirting out of each injector, with no air bubbles. No air coming out of bleed screw on fuel filter either.
Puzzled why she won't fire up. Any thoughts and or suggestions, appreciated. Hate the thought of having to have pump rebuilt because O-ring was leaking. Tractor ran fine up to this point.
