Comparison TN vs TL vs TS
   / TN vs TL vs TS #11
The TS has the same cab as the TL until the TS-A or whatever the big glass door version is called. RickB will show up and rap my knuckles on this but its more or less true.
I won't disagree with you, that was the cab I was referring to. The one with the big glass door. It was a great cab and a lot more room then the TL-A that I did use. It seems like a long time ago now and many model designations ago.
   / TN vs TL vs TS #12
Yup I can't keep up anymore. Hopefully they just stick with the 4,5,6 that line up roughly to what Deere and MF are using for numbers.
   / TN vs TL vs TS #13
You must think I haven't learned anything in the last few years.
So is it more true, or less true? :anyone:
   / TN vs TL vs TS #14
To a layperson, for visibility and getting in and out the doors, the cab on the TL and early TS/40 and even the TM/60 series is the same. The TM/60 has a nice cushy jump seat vs the half cheek foam scoop on the TS/40 or the nothing on the TL's I've been in. The base models of TL/TS have the right side area kinda tight with the long shift levers.
   / TN vs TL vs TS #15
Hi can any one advise on tl or ts new Holland tractor as I'm wanting to up grade my 4600 loader
for something around 2004-2008 with a loader quickie or trimma
2007 Saturn Sky Convertible Coupe (A54815)
2007 Saturn Sky...
Native American Wooden Statue (A55853)
Native American...
2011 PETERBILT 388 (A55745)
2011 PETERBILT 388...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
2015 Kubota KX91-3S2 Mini Excavator (A55973)
2015 Kubota...
