tn 75s shuttle question
   / tn 75s shuttle question #1
GarethVW
Northeast Ohio
New Holland TN75S
I recently bought a tn75s. I really like the tractor but there are a few things that need fixed or changed. The first thing that needs fixing is when you put the shuttle in forward or reverse from a stop you have to push the clutch to make the tractor move. I have read that the seat switch is often to blame but everything else associated with the seat switch seems to be working. Also the tractor is curently on a job site so I can't look at it right now, but besides the seat switch what could cause this? Thanks!
   / tn 75s shuttle question #2
Are you getting any error codes?
The transmission light does blink. I don't know the pattern because Unfortunately he tractor is on a job right now. I will try to get the code next week when I am on the job.
No pattern to the blinking, it is just steady.
   / tn 75s shuttle question #5
i have a tn75s also and when i first got it last year it would do the same thing as yours is doing only when it was cold out and if the tractor had been left out in the cold. i took the seat switch and disconnected the harness under the seat that goes to the switch and just ran a jumper wire on the harness. It has never done it again. at least you can try this and if it solves the problem you can replace the switch or make some adjustments or leave it bypassed. Good Luck
Sorry I haven't been here in a while. I wanted to let you know the seat switch was the problem. Is it so nice to have that working properly! Thank you to all who helped me out!
2013 PETERBILT 386 MID-ROOF SLEEPER (INOPERABLE) (A58214)
2013 PETERBILT 386...
Mini Excavator Quick Coupler (A55272)
Mini Excavator...
IRET13 ELECTRIC TRICYCLE (A58216)
IRET13 ELECTRIC...
2368 (A58376)
2368 (A58376)
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2015 Volkswagen Jetta Sedan (A55758)
2015 Volkswagen...
