tn 75s shuttle question
   / tn 75s shuttle question #1
GarethVW
Northeast Ohio
New Holland TN75S
I recently bought a tn75s. I really like the tractor but there are a few things that need fixed or changed. The first thing that needs fixing is when you put the shuttle in forward or reverse from a stop you have to push the clutch to make the tractor move. I have read that the seat switch is often to blame but everything else associated with the seat switch seems to be working. Also the tractor is curently on a job site so I can't look at it right now, but besides the seat switch what could cause this? Thanks!
   / tn 75s shuttle question #2
Are you getting any error codes?
The transmission light does blink. I don't know the pattern because Unfortunately he tractor is on a job right now. I will try to get the code next week when I am on the job.
No pattern to the blinking, it is just steady.
   / tn 75s shuttle question #5
i have a tn75s also and when i first got it last year it would do the same thing as yours is doing only when it was cold out and if the tractor had been left out in the cold. i took the seat switch and disconnected the harness under the seat that goes to the switch and just ran a jumper wire on the harness. It has never done it again. at least you can try this and if it solves the problem you can replace the switch or make some adjustments or leave it bypassed. Good Luck
Sorry I haven't been here in a while. I wanted to let you know the seat switch was the problem. Is it so nice to have that working properly! Thank you to all who helped me out!
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53472)
2019 Krause...
AMADAS SPC-6 LOT NUMBER 257 (A53084)
AMADAS SPC-6 LOT...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
