TN 70 Rear Hydraulics
   / TN 70 Rear Hydraulics #1
koamfps
Michigan
NH TN70DA & NH 2120
Ok this may sound dumb but here it is. My Rear hydraulics on my TN70 have no release on the female end to remove my hoses. I have to use a screw driver to release the hoses my pushing in the outer ring on the female side. It this standard?
I know this is a Pain in the A** is there an easier way..
   / TN 70 Rear Hydraulics #2
You should be able to push the male end in and then make a quick pull to get it out. Sort of all in one quick motion.
Brian, I hope your right that is giving mt fits. My 2120 NH is a no brainer but this one #%*%*^(()_%$!#~@
Thank you
   / TN 70 Rear Hydraulics #5
These can be a real pain. I had to replace 3 or 4 of my couplers. You push real hard and pull real fast.
I took them apart and found that they had rust behind the release collar. I replaced the first one with the same thing. It is ~3x what the cheaper manual release coupler cost (what came on the A or D models). I replaced the other ones with the cheaper manual one. On the manual one you push the outer ring to release the coupler. Much easier to remove in the long run (I don't remove mine often as they are used with the loader).
MtnViewRanch..... It worked well thank you
2014 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2014 DRAGON...
2017 CATERPILLAR 299D2 XHP SKID STEER (A51246)
2017 CATERPILLAR...
VARIETY BOX OF SCHUMACHER BATTERY CHARGERS (A51248)
VARIETY BOX OF...
Kubota Salt-Spreader (A52384)
Kubota...
UNUSED LANDHERO IH-IW21 1" AIR IMPACT WRENCH (A51248)
UNUSED LANDHERO...
2018 VOLVO ECR88D EXCAVATOR (A51246)
2018 VOLVO ECR88D...
